PoiBoi
- 10
- Apr 19, 2021
Pasadena,
Maryland
Hello all, the ecu in my Non-Turbo, manual, awd Galant GSX went out recently. It looks like what i think is an ISC driver chip went up (attached picture). I will be contacting ECMtuning to get this sent in and repaired, however I have some questions about it that im not finding solid answers for on the forums after searching (if i missed anything call me dumb and send me a link). Apologies if this is the wrong forum category.
What burnt was the second driver chip from the right, that is for the ISC correct?
I tested the ISC, i believe the shop it was at used an aftermarket one from Napa. It tested good, 39ohm, if a little high on all coils. Is there anything else on that circuit in the car that could cause this? What else should I test? (black top, replaced a brown top a little over a year ago that had gone bad. Car ran and idled fine after this)
I have a spare Non-Turbo Manual ECU that I'd like to use, however it has a knock circuit. My GSX does not have a knock sensor, and not having one connected, if im correct, will throw a code and perma-retard my timing. Is there anyway to 'delete' or ground out the knock circuit in order to not have that? Wasnt able to find a straight answer for this on the forums. I am not worried about not having a knock sensor, car is driven gently and non-turbo.
Thanks for your time
