G2 GSX Rosso Nero Zero
zer_0
73
65
Mar 28, 2007
Polotsk, Europe
CLEAN LOOK
Mitsubishi Eclipse G2 GSX 4A3AL54F6VE......
1997 Year
Made in USA
AWD
AT 4 speed
4G63Turbo
Coupe body
Color Minden Silver Pearl
Modification
Engine
Cylinder head porting
GSC Power Division Stage 1 Camshafts 268/268
Hundai OEM rocker arm adjuster lifters
Fidanza adjustable cam gears — "Limited Edition" black
Gates Racing Performance timing belt kit
Gates Racing Performance belt full kit
Original turbo intake manifold + porting
Magnus heat barrier intake manifold
Topline pistons with rings set 8.0:1
OEM Mitsubishi Lancer Evolution 8 turbo connecting rods
OEM MMC metal head gasket
ARP head studs
True Mitsubishi MHI Evolution 3 turbocharger
Stainless steel oil feed line
Removed EGR
Removed cruise control
Paint valve cover
Clear cam gears cover
Extreme PSI spark plug cover
Oil cap Greddy
OEM external oil cooler filter bracket assembly: Mitsubishi Lancer Evolution 3
OEM oil cooler kit
Custom oil catch tank
Prothane motor mount inserts
Greddy radiator cap 1.3kg/cm2
Samco Sport radiator hose kit
Engine electronics
OEM Mitsubishi Lancer Evolution 8 ECU
AEM TRU-BOOST Gauge-Type controller
AEM Gauge-Type wideband UEGO controller
Omni-Power Mitsubishi Universal Map Sensor 3 bar
Turbo timer
MSD spark plug wires 8.5 mm
Spark NGK BPR7EIX – 0.55 mm
Fuel
Walbro 250 fuel pump
Fuelab 818 fuel filter
6 AN fuel feed line kit (Filter to Rail)
OEM Mitsubishi Lancer Evolution 8 fuel injectors 560
6AN fuel feed line kit (Rail to AFPR)
Aeromotive A1000 fuel pressure regulator 6AN
Air
K&N replacement round air filter + adapter
Custom air filter stainless steel heat shield
Injen intake pipe
Liquid cooling of air
Custom stainless steel intercooler piping 2.5'' + silicone HTS and Extreme PSI+ T-bolt Clampco
Bypass valve Greddy Type RS
OEM Mitsubishi Sigma throttle body 2.5"
Exhaust
Mr. Gasket copper exhaust manifold gasket
OEM Mitsubishi Lancer Evolution 3 exhaust manifold
OEM Mitsubishi Lancer Evolution 3 O2 housing
Custom stainless steel exhaust manifold heat shield
Downpipe Megan Racing 2.5-3" (Inlet/Outlet)
Deleted catalyst exhaust gas
Custom exhaust pipe 3"
Exhaust mufflers HKS
Transmission
Swap manual transmission
Swap OEM limited slip rear differential
Goodridge complete clutch line
Megan Racing short shifter kit
Energy Suspension shifter kit
DSM under hood shifter bearings
ACT Street Lite Flywheel
ACT 2600 + ACT Street disc
Suspension
Tein Super Street coilovers kit + auxiliary KYB shocks kit
Custom front strut tower brace
Custom rear strut tower brace
Energy Suspension Hyper-Flex master bushing set
OEM Mitsubishi Galant VR – 4 front knuckle (160 mm)
Custom front camber adjuster
Ingalls rear camber adjuster (-1° to +3°)
Brakes
OEM Mitsubishi Lancer Evolution 8 (Brembo)
Goodridge brake line kit
Interior
Mitsubishi Lancer Evolution 6 Recaro TME Seats
Full altered inside of the car: red and black (rosso nero)
Steering wheel Raid
Pedal cover Type R
Exterior
Painting a car red with black roof and wing (rosso nero)
JDM halo projector headlights
Painting rear panel
Shaving:
Removed door handles
Removed the front bumper turn signal
Removed custom sunroof
Removed drain grooves on the roof
Removed rear windows wiper & windows washer
Removed antenna
Welding hole in the left rear fender
Removed rear lights
Fluids & Lubricants
Red Line 5W50
Red Line MT85 Manual Transmission & Transaxle Lubricant 75W85 GL-4
Red Line 75W90 High Perfomance Gear Oil (for LSD)
Red Line Power Steering Fluid
Red Line RL-600 Brake Fluid
Red Line Water Wetter
Wheels & Tires
Kosei Op Magnum wheels 18"
Federal SS 595 RS - R tires (225/40/18)
TPI nuts black
Custom front and rear wheel spacers 8mm
Power after modifications
Preliminary result - 350 H. P.
I bought the car in 2006. Bought at auction in New Jersey. In an emergency condition.
Specification. Year 1997. 4G63Turbo engine. All wheel drive. Automatic transmission. Color silver metallic.
Yes, thank you, this Minden Silver Pearl
Modification:
During repairs, replaced the automatic transmission to manual transmission, set the rear LSD. Machine color changed to red black. Removed door handles, removed antenna, painting rear panel.
Injen intake pipe, front mount intercooler OBX, custom stainless steel intercooler piping 2.5'' + silicone HTS and Extreme PSI+ T-bolt Clampco, custom blow - off valve, custom fuel pressure regulator, Walbro 250 Fuel Pump, Samco Sport radiator hose kit, custom oil catch tank, paint valve cover, Extreme PSI spark plug cover, custom front strut tower brace, Tanabe yellow shocks and lowering springs kit, custom rear strut tower brace, Hawk HPS front and rear brake pads, Goodridge brake line kit, steering wheel Raid, pedal cover Type R.
Sound
Nakamichi CD400, Prology DVD — 350U, Prology HDTV — 707S ; front; Oris + Ivolga, rear Infinity, subwoofer Free Air Pioneer TS — W307F; amplifier: front Kenwood KAC 8401 - 4 channels, rear Fusion 402 – 2 channels, subwoofers Kenwood KAC 8152D; kondensators Prology 1F + Oris 0,5F
Noise insulation STP
Yes, the road was long. Thank you!
PS Exterior now changed :) Photo lay out later.
The second modification
Tein Super Street coilovers, Hundai OEM rocker arm adjuster lifters , AEM TRU-BOOST Gauge-Type controller, removed cruise control, Fuelab 818 fuel filter, 6 AN fuel feed line kit (Filter to Rail), Goodridge complete clutch line, Megan Racing short shifter kit, Energy Suspension shifter kit, DSM under hood shifter bearings, Energy Suspension Hyper-Flex master bushing set, Ingalls rear camber adjuster, OEM Mitsubishi Sigma throttle body 2.5”, Kosei Op Magnum wheels 18”.
JDM halo projector headlights, full altered inside of the car – red and black, OEM Mitsubishi Outlander front brakes bolt-on kit (front brake rotors 294 mm), OEM Mitsubishi Space Wagon AWD rear brakes bolt-on kit (rear brake rotors 284 mm), new custom front strut tower brace, custom front camber adjuster, auxiliary KYB shocks kit, bypass valve Greddy Type RS, oil cap Greddy, 6AN fuel feed line kit (Rail to AFPR), Aeromotive A1000 fuel pressure regulator 6AN, MSD spark plug wires 8.5 mm, battery moved to the trunk, custom exhaust manifold heat shield, downpipe Megan Racing, removed catalyst exhaust gas, removed rear windows wiper and windows washer.
Cylinder head porting, GSC Power Division Stage 1 Camshafts 268/268, Fidanza adjustable cam gears — “Limited Edition” black, Gates Racing Performance timing belt kit, Gates Racing Performance belt full kit, OEM turbo intake manifold + porting, Magnus heat barrier intake manifold, Topline pistons with rings set, OEM Mitsubishi Lancer Evolution 8 turbo connecting rods, OEM MMC metal head gasket, ARP head studs, OEM Mitsubishi MHI Evolution 3 turbocharger, stainless oil feed line, removed EGR, paint valve cover, clear cam gears cover, OEM external oil cooler filter bracket assembly: Mitsubishi Lancer Evolution 3, OEM oil cooler kit, Greddy radiator cap, custom amplifiers spars
Mitsubishi Lancer Evolution 8 original ECU, AEM Gauge-Type wideband UEGO controller, Spark NGK BPR7EIX – 0.55 mm, OEM Mitsubishi Lancer Evolution 8 fuel injectors 560.
K&N replacement round air filter + adapter, custom air filter heat shield.
Mr. Gasket copper exhaust manifold gasket, Mitsubishi Lancer Evolution 3 original exhaust manifold, Mitsubishi Lancer Evolution 3 original O2 housing, custom stainless steel exhaust manifold heat shield, exhaust mufflers HKS.
ACT Flywheel, ACT 2600 + ACT Street disc.
OEM Mitsubishi Galant VR – 4 front knuckle (160 mm) bolt – on Brembo, OEM Mitsubishi Lancer Evolution 8 brakes.
Mitsubishi Lancer Evolution 6 Recaro TME seats.
New painting a car red with black roof and wing, removed rear lights, painting rear panel.
Yokohama S. Drive (ASO1) tires (225/40/18), TPI nuts black, custom front and rear wheel spacers.
Sound – no, noise insulation – no.
Tein Installation Instructions:
"This product is designed for off ROAD USE ONLY. The product may only be installed in race vehicles, show vehicles and other specially configured vehicles intended for off road use. THE PRODUCT MAY NOT BE INSTALLED IN VEHICLES DRIVEN ON PUBLIC ROAD".
This is true. Roads should be smooth as table cover. These roads have little. For the road had to rework the suspension.
The modification:
Omni Power Mitsubishi Universal Map Sensor 3 Bar
MAF OEM Mitsubishi Lancer Evolution VI
Intercooler Koyo OEM Mitusbishi Lancer Evolution VI
Aluminium performance radiator Mishimoto
Red Silicone Vacuum Hose Vibrant
Remastered restyled front bumper
Remastering the front right's headlight for Cold Air Intake
Cooling and ventilation under the hood
Liquids and oils Red Line
