1. Join the Community!
Sold FWD* 1995 GST/2GB
Posted by camocorvette, Jul 2, 2020
Please Support VR-Speed Factory
  1. camocorvette
    camocorvette Proven Member
    64
    20
    Joined Aug 5, 2012
    Spanaway, Washington
    *SOLD*Will update, ask questions you have. Thanks*SOLD*
    $4800 OBO*SOLD*
    1995 Mitsubishi Eclipse GST
    Turnkey, Street ready.
    Red, DSM stamped multiple places, frame stamp and so on...
    Evo3 OEM block with GSC balance shaft delete kit, front case, oil gears, OFH, water pump, all gaskets less then 800 miles, no leaks.
    2g Head, 1G blacktop CAS, Kiggly HLA
    Evo8 ecu
    Entire wire harness trimmed/tucked. More so just for efficiency. I removed any wire and components not in the car.
    Stock exedy clutch, torque solutions bushings for all shifter boot and linkage. SS STM clutch line. (Trans was off literally last week. Fixed 3 rear trans mount bolts that wobbled out. Degreased and re greased TOB and ball. Clutch looks good albeit some surface rust on clutch cover)
    Ole betsy runs great. Just dyno'd 290 at Enflish racing. Time before at English it dyno'd 300/315 to the wheels. The fuel pump, new front tires and a street tune is pretty much the next step for it .
    i just bought a DW400 pump, yet to install. It will dyno 330ish with a new dyno tune at english.
    16g turbo is Mitsubishi. Rebuilt with turbo lab of america kit. Complete running car, all gaskets and seals less then 800 miles. I drove it to english and back just fine. That was 250 miles at least. Then I have tooled around town another 400 or so. We did 13 pulls on the dyno and it ran great. The fuel pump wasn't supporting more boost so its tuned at like 18-19 psi with alittle spike to 22 at AFR 12.
    I will get pictures of anything you want. Pretty much every nut and bolt on the car has been replaced/cleaned. Metal cleaned of surface rust if any (minimal on side skirts and rear wheel wells, front perfect) then etch primed and painted or undercoated.
    Car weighs 2800 with a full tank of gas.
    No A/C
    No AirBag/SRS
    Non abs car originally
    No cruise
    No power mirrors
    No power seats (front leather, manual adjustable)
    No sound padding
    No carpet
    Rear privacy cover
    I really didnt cheap out on it. Been building it the past 2 years. I had a blast in it so far
    My thoughts are put a cage in it, build the block, 6466, transmission and drive it. If it doesn't sell that's what I'll do. Full mod list in pictures
    Street Build 508  3
    300 whp · 315 lb/ft · 2G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
