Please Support Morrison Fabrications
Please Support Rix Racing
1G Fusion rims
Steve92talon
156
21
Jul 3, 2019
Fernie, BC_Canada
So unless u dont already know rims from a 2010 fusion are a bolt on. Even the hub size is correct. Scored a set of winter tires on black steel rims from a 2010 fusion and they bolted right up. U can use the stock talon nuts if u look close the bottom of the nut has a taper for steel rims. Same as any Toyota u can bolt steel and aluminum rims with the same nut.
