STM tuned
Supporting Vendor
- 572
- 55
- Feb 14, 2008
Rochester,
New_York
Our inventory of stocked ARP Bolts is ever increasing, especially with the types of product we carry.
The ARP DSM/Evo Stainless Exhaust Manifold Stud set shines in both function and form with ARP's stainless steel alloy, which is nominally rated at 170,000 psi tensile strength, which is substantially stronger than Grade 8 hardware. Ideally suited for installing exhaust headers, the 8mm studs have a unique "nut starter" nose and a hex-broached tip - which allows the studs to easily be installed using an Allen wrench.
Match your shiny manifold bolts with a set of our ARP Stainless Turbo Bolts for your DSM!
The ARP Custom Age 625+ Head Stud Kit is the newest release from ARP. These fasteners deliver a 55% increase in tensile strength over the OEM Torque to Yield (TTY) head bolts.
The very popular ARP L19 material (comparable to A1 Technologies H11 Tool Steel) is a premium steel that is processed to deliver superior strength and fatigue properties. L19 is a very high strength material compared with 8740 (standard ARP headstuds) and is capable of delivering a clamp load at 260,000 psi.
Need a simple and cost effective upgrade to your engine for "insurance"? Have that stock turbo and want to push your engine or still have that stock bottom end on a bigger turbo? Don't reuse those old head studs, make sure your engine will last the way it's meant to - throw in a set of ARP Head Studs and keep your head mated to the block, the way it was intended!!!
Got huge lift, stiff springs, and massive boost from your gargantuan turbo?
Make sure your cam tower bolts have been upgraded - ARP's newest offering for the 4G63 platform is their Cam Tower Bolt Kit. Another cheap upgrade for some peace of mind.
Rod Bolts! Cam Gear Bolts! Balancer Bolt and Washer! Extended Wheel Studs!
All these are in stock and waiting to ship to your door TODAY.
Give us a call and get your ARP Bolts shipped to you today!
585.226.8226
585.226.8226
