Josh_JDTRacing_com
- 8
- Nov 4, 2019
Pawtucket,
Rhode_Island
I recently purchased a Fueltech FT450 ECU with Harness, sensors, Smart Coils. I'm curious to see who else has went with a Fueltech in their DSM and what if any issues did you have? Any regrets? Any advice you can give someone installing one of these for the first time.
I have a 1990 Eclipse GSX, current parts list is as follows and new parts I am putting in are at the bottom.
- 6 Bolt Block
- Wiseco Pistons
- Manley Turbo Tuff I-Beam Rods
- 22mm Wrist Pin’s
- Fluidampr Crank Pulley
- FFWD Cylinder Head
- Supertech Dual Valve Springs
- Kelford 272 Cams
- 1mm Oversized Valves
- Cast T3 Manifold
- Holset HY35 Turbocharger
- TiAL 38mm External Wastegate
- TiAL Blow Off Valve
- Spearco 28”x10”x4” Intercooler
- Custom 2.5” Intercooler Piping
- Mishimoto Aluminum Radiator
- Fuel Injector Clinic 1650cc Injectors
- Walbro 525lph Hellcat Fuel Pump
- Aeromotive Fuel Pressure Regulator
- Fuelab 8AN Filter w/ Stainless Element
- 8AN Braided Fuel Feed Line
- 8AN Braided Fuel Return Line
- Custom 3” Downpipe
- Custom 3” Exhaust
- RRT Motorsport Transmission
- Clutchmasters Twin Disk Clutch
- Clutchmasters Steel Flywheel
- Clutchmasters Hydraulic Release Bearing
- 4 Bolt Rear End
- Solid Shifter Cable Bushings
- Border Custom Full Coilover Drag Suspension
- CTSV 4 Piston Brembo Calipers
- 13" EBC Rotors
- CTSVBrakeSwap.com Adapter Plates
- StopTech EVO Stainless Steel Braided Brake Lines
- AEM Wideband
- AEM Boost Gauge
- AEM Oil Pressure Gauge
- AEM Fuel Pressure Gauge
- AEM Water Temperature Gauge
- AEM Speedometer
- ECMLink V3 - Speed Density on Flex Fuel
- Tuned by Kenny Kline
New parts going in,
- FuelTech FT450 w/ Full Harness
- Davies Craig EWP150 Electric Water Pump w/ Thermatic Fan Controller
- Civic 3 Pass Aluminum Radiator 1/2 Size w/ 16AN Inlet/Outlet
- Frontline Fabrication Water Pump Delete
- Frontline Fabrication Thermostat Housing
- 16AN Stainless Steel Braided Coolant Lines
- JMF Fuel Rail
- Custom Turbo Manifold
- TiAL 46mm Wastegate
- TiAL 50mm Q Blow Off Valve
- Custom RAC Dual Ball Bearing Turbo (good for 800HP)
- New Larger 4" Thick Intercooler
- 6 Bolt Block
- Wiseco Pistons
- 22mm Wrist Pin’s
- Kelford 272 Cams
- Cast T3 Manifold
- Custom 3” Exhaust
- 4 Bolt Rear End
- 13" EBC Rotors
- AEM Wideband
- AEM Boost Gauge
- AEM Speedometer
New parts going in,
- JMF Fuel Rail
