Please Support JNZ Tuning
Please Support ExtremePSI
420A How to remove injectors from 420A fuel rail?
daveeclipse99
74
Dec 10, 2008
grand rapids, Minnesota
does anyone know how to take the injectors out to replace the stock ones ?
they make the search option on this forum for a reason but since i feel like being nice you unbolt the fuel rail and i cant recall if the 420a is a banjo fitting like the 4g or not but you disconnect the fuel line and there you go.
This is what i did.
1. lift up back seat take off the round plate diconnect the fuel wire.
2. start car until it dies out start again a few more times to relive fuel pressure.
3. disconnect negative battery cable.
4. disconnect all the wires to the fuel injectors.
5. take a 13mm wrench ratchet and remove the 2 bolts holding on fuel rail.
6. Remove the two bolts and unclamp the hose on the side of the fr.
7. pull out the fuel rail straight back it will take a little strength.
That is how i did it.
