Fuel Questchun?????
-=Grant-TSI=-
Mar 24, 2003
i am looking to get a Walbro- 255 LPH high pressur fuel pump. my question is can i use this with stock injectors till i get bigger ones? and will i need a high pressuse fuel line? what other pumps do you recomend?
well, let me ask you this firts...do you NEED a 255? You know a 190 can support a TD05 20G right? Which could build almost 450 HP.
A 255 will not only require injectos, but a fuel pressure regulator, because you stock one wont handle the fuel from a 255. if you NEEED to have to 255 I would reccommend 660 injectors and get a Super AFC, because this fuel system will require some tuning.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
