mace01
- 48
- 0
- Jan 17, 2003
Geneseo,
Illinois
Hey everybody,
I've got a little problem bugging me here. My 91 Plymouth Laser turbo ran great up until about a week ago, when I went down to start it, and it turned over perfectly, but wouldn't start. I couldn't hear the fuel pump prime when I turned the key to the on position, so I figured that was the problem. Later that day, I was able to start the car and drive it perfectly except for one time that it started only about halfway, then choked and died, so I cranked it again and it was fine.
Now it will not start again. I listened for the pump when a friend turned the key to on, nothing. When I supplied power directly to the pump through the connector on the pump itself, I heard it whirring, but the car still wouldn't start. I seem to be getting no voltage from the stock battery at that connector however. Nothing happened when I tried the fuel pump check connector (or what I thought was the fuel pump check connector), so I'm stumped. I guess I'll pull the ECU and see if any capacitors are leaking. Any other ideas for things to check or try??
Thanks,
Jeff
Thanks,
Jeff
