FS: Clean 1995 Eclipse GSX 6-Bolt
projx
92
Jan 3, 2012
Brooklyn, New York
Contact Info: [email protected] Or txt me 646-249-2324
Year: 1995
Make: Mitsubishi
Model: Eclipse GSX
Color: White
Mileage: 86k on body and roughly 65-66 on engine
Transmission: Manual
Price: 5.8 or OBO
Description: Hey guys, I'm selling a 1995 Mitsubishi Eclipse GSX 6-Bolt swap from a Gvr-4.
The body has almost 86k and the engine has about 65k.
The car is clean and drives good. In no rush of sale, just seeing what can be offered here and if anyone wants to pick up a very clean DSM! I've daily drove this car since it was bought didn't put too many miles on it. Only time this car has been towed was because the slave went out. Reason I want to sell it is because times are getting hard and having some money saved up is good. Im posting all the pics i got on the work. Not hiding anything at all! This car has been driven to Boston and back with no problems or break downs at all! Seen the track once at English Town no. No Anti-lag has been enabled on the car since my ownership. Never Launched hard! Amount of launches done was 5 and that was before all the new parts when the car was still running a T25 and a 2100 ACT.
Will post up more interior pictures in a day or two. Also the front bumper has been aligned properly and sits with the body nicely.
These Row of pictures were taken literally last week!
Note These pictures starting from here is when the new parts were installed at a shop and the rotors are not rusty like that atm, The car wasn't driven for a month before these installs. Which was maybe like 3-4 months ago
The GSX 2step - YouTube
Mods
Punishment Racing Intercooler Less than 100miles
Greddy blow off valve Type-S Less than 100 miles
Timing Belt Kit from ExtremePSI Less than 800miles [ExtremePSI]
ACT Xtreme 2600 Clutch with Light Weight Flywheel Less than 800Miles [ExtremePSI]
New Clutch fork less than 800 miles [ExtremePSI]
Braided Clutch lines less than 800 [ExtremePSI]
New Slave and Master Cylinders less than 800 miles [ExtremePSI]
Evo3 16G No PLAY and no smoke
Innovative WideBand
Boost Gauge installed aswell Don't know which company
Big Brakes with drilled and slotted rotors
Greddy 3" Exhaust No cat
Red Valve Cover resprayed to Black
HID 8000k less than 1k Miles
New NGK BR7ES Less than 200miles
ECMLink V3
Wally 225 Single pump
PTE 680 Injectors
I also have an uninstalled Mishimoto Rad X-line will throw that in for an extra 270 never been installed or seen any liquids.
K&N Intake
MAF Installed
Pros
Drives great
Very very clean interior for a DSM and a car this old.
NO Rips in seats at all!
On a count of rust its a 5/10, no rust in engine bay nor in wheel wells or important frame parts.
All the new major parts that need to be serviced
For a DSM it has been very reliable to me.
Head Liner has been replaced and probably has less than 2k miles since it was installed.
New Oil Royal Purple synthetic 5-30w less than 800 miles
New transmission oil Pennzoil Syncromesh Less than 800miles
New Royal Purple Oil filter Less than 800miles
Cons
*Needs a tune. I tuned it just for cruise but still pulls nicely.
I noticed because of the tune its effected the way it shifts. Noticed every time i tuned it better to spec it shifted better.
*I'd say the transmission is 7/10 but then again no DSM transmission is good untill it has a rebuild. As well as it probably would shift better if it had Polly engine mounts. The ones in there now are not fully destroyed but I can see it would be better to change them. Goes into every gear just fine, Only when going into reverse you can hear a little clank sound but it never pops out of gear and doesn't grind or clank any other gear!
*In the morning it does need to warm up before driving i think its because the car needs a new coil pack or plug wires.
* Rear bumper have a few paint chips cause of asshole Brooklyn drivers. In the video of the two step you can see where the chips are, Very small. I'll post a better pick up
* Has like fake coil over ****s, doesn't ride too rough so a change in suspension will be in favor. No seized shocks or anything. Drove this car daily doesn't bother me too much at all.
Receipt from ExtremePSI on the parts that were bought and installed.
Products ordered
SKU Product Item price Quantity Total
PSI-DSMTBKIT Extreme PSI Timing Belt Kit: Mitsubishi Eclipse 90-99
Options:
Timing Belt: OEM MD326059
Tensioner: 90-92 MD164533
Tensioner Pulley: 90-94 MD129355
Idler Pulley: 90-99 MD156604
Balancer Pulley: 90-94 MD115976
Balance Shaft Belt: OEM MR984778
Balance Shaft Eliminator Kit: Not Selected
$289.85 1 $289.85
MIT-MD733623 OEM Clutch Slave Cylinder Assembly : Mitsubishi Eclipse 90-94 AWD $77.18 1 $77.18
MIT-MB910562 OEM Clutch Master Cylinder Assembly : Mitsubishi Eclipse 95-99 $114.85 1 $114.85
PSI-2GCLUTCHLINE Extreme PSI Complete Clutch Line (Slave to Master Cyl.): Mitsubishi Eclipse 95-99 $39.00 1 $39.00
PSIK-MB1-XTSS-150 ACT Xtreme (2600) Clutch Kit + ACT StreetLite Flywheel
Options:
Model: AWD (6-bolt)
$678.69 1 $678.69
Subtotal: $1199.57
Shipping cost: $0.00
Handling Fee: $7.50
Total: $1207.07
Don't know to be honest. Old owner did the swap. I think it might have because the 7 bolt crankwalked might be (#1 reason why people do a 6bolt swap, or #2 because it was a 7bolt and a chance of crank walk LOL)
This is a great looking DSM, my friend and certainly within my price range.
Thanks! :D
Oh and to mention, the "Fake coilovers" Is Ground control adjustable lowering kit on eibach springs! I just call em fake coilovers cause thats what they really are. Also one small damage since the pictures were taken, i hit a rock and on the right side where the squarish part on the sideskirt near the wheel well, that broke off. We all know thats like 30-50 to replace.
naws i fixed it up, Intercooler was blocking it from sitting flush, Cut out some pieces and fits nicely now! :)
Noooo! was gonna ask if you still had it! my tax refund would have picked this up
Damn sorry Rich! :(!!!! OH well. Bro save up and get an evo. Thats what im planning to do. Yet the 240sx has me my god damn throat. I really wanted to pick up a 240 just to have some sideways fun. Yet my brain is telling me to save up for an evo. Uaghh, decisions decisions.
