reborn750
- 106
- 1
- Oct 7, 2010
Brookings,
South_Dakota
Sorry if this is in the wrong category but i couldnt find anything for threads relating to wiring.
After removing my entire stock wiring harness after going standaloneMegasquirt on my 420a Eclipse i have run into a few problems. Everything in my interior works fine still except for my power windows, power sunroof, and my starter. I want my starter to still be on the ignition key switch. I figured i would just run the wire from the starter solenoid to pin 87 (where power is needed) on a relay, starter wire from ignition switch to pin 86 (switched 12v), and pin 30 to power (12v) and 85 to ground. I tried to start and nothing happened.
All my other relays (fuel pump, and ECU components) work great and they are all new relays. Am i on the right track or am i completely going at it the wrong way?
Also, are the power windows and sunroof on a relay? i checked the one power windows fuse i could find and it was good. Only thing i can think of is that i removed a relay that was running them when i pulled the old harness under the hood. Also wipers are not working.
