Ludachris
Founder & Zookeeper
- 8,053
- 3,072
- Nov 12, 2001
Newcastle,
California
A new bolt-on DSM turbo from FP.
Now if only we could get FP to come back and get involved here on the site.
New for 2020! All FP Black model turbos will come standard with a black coated compressor cover!
- Compressor wheel - 82HTZ
- Flow rating - 71LB per minute
- CW Measurements - 59.1MM Inducer / 82MM Exducer
- TW Measurements - 67.3MM Inducer / 58.8MM Exducer
- Compressor Housing - 84MM Flow Advancement Port Cover
- Turbine Housing - FP 10CM
- CHRA - XR Ball Bearing
- Oil Line - Not Included
The FP Black Ball Bearing Turbocharger for DSM features our 82MM HTZ wheel rated at 71LB a minute. This turbo uses our Xona Rotor ball bearing center section for maximum performance and reliability. We also developed our own 10cm housing for maximum flow while retaining bolt on fitment. Due to the flow of this turbo and turbine housing, this will only be offered with an external wastegate off O2 setup.
