GoRiceGo4g63
- 1
- Mar 25, 2019
mesa,
Arizona
Ok let me share a little story with you guys. I installed some bc 264/272 cams the other day. Without thinking I just threw them in and put everything back together. I tried starting it and it wouldn't start. Then one of my friends asked if I blead the lash adjusters (lifters). I panicked and went ahead and blead them after several attempts of trying to start it. After I blead the lifters and reassembled it. It started right up but was making a noise like I bent the valves. I went into panic mode and thought I bent my valves. Several friends told me that if they were bent. It mostly wouldn't start. I was going to just test it I already know I had messed up. I started looking for parts. My friends instead that I test it. So I went and got a cylinder leak down tester. I just got done testing it and right in front of my eyes I seen that I didn't bend any valves. Moral of this not so short story. Keep good friends around, and test before you assume.
I know #3 rings are starting to wear.
