So I decided to do this mod the other day and I followed the directions from vfaq:
2G Fog Lights with Parking Lights
However, the instructions were a bit sketchy as far as pictures and clear instructions. I did get it to work, but didn't like the setup, so I went about altering the mod myself.
Like the original states, get an in-line fuse holder and put male spade connectors on each end. Then pull the fog light fuse out, and put it in the holder. Then pull your tail light fuse (left one in the picture) and put the spade connector in with the fuse. Then link the in-line fuse back to the power side of the fog light fuse location.
After that's done, you're finished. The fog lights turn on with your parking lights. They still operate normally with the switch and the high/low beam settings. You won't have to switch the fogs off in order to get them to shut off either. They will turn off with the fog switch as well as the normal light switch.
