  • Join the Community!
    DSMtuners is a massive archive of DSM information - but more importantly, it's a COMMUNITY! Join in and participate with other DSMers, and invite all of your DSM friends to make this place their home. Chat with others, create a build thread, post questions and answers. Get involved! Logging in will also remove many of the advertisements, along with this notice. ;) It will also allow you to view images in threads.
Please Support Morrison Fabrications
flywheel???
Status
Not open for further replies.
kareem17
92
Oct 14, 2003
Sarnia, Ontario_Canada
Sorry for this newbie question, but what is a flywheel? what is it good for? do 2g's have a stock flywheel?
4g64GST
197
Jan 29, 2004
Dallas/Fort Worth, Texas
:cry: :cry: :cry: :cry: :cry:
ok a flywheel is the metal disk that goes in between the motor and transmisson. I bolts to the crankshaft of the motor and then the clutch presses up against it to turn the trans. it is also used to start the motor the starter uses the gears on the outside to turn the motor over and start it.
yes you have a flywheel and yes all cars have some sort of flywheel.
O by the way you cant see it so dont go digging for it. you would have to pull the trans out.
:thumb: :thumb: :thumb: :thumb: :thumb:
all you guys can thank me later
kareem17
92
Oct 14, 2003
thanks alot. If my clutch wears off, i've heard it is better off to get a ACT 2100 because my car is a FWD. Should I get a upgraded flywheel to go with it?
leet
10,925
30
Jan 10, 2003
Atwater, California
If all you do with the car is drag, stick w/ either the stock flywheel or an ACT XACT wheel.
I have a Fidanza, and as long as they are machined correctly, they are AWESOM.
Status
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com RixRacing RockAuto RTM Racing STM Tuned VR Speed Factory
