  • Join the Community!
    DSMtuners is a massive archive of DSM information - but more importantly, it's a COMMUNITY! Join in and participate with other DSMers, and invite all of your DSM friends to make this place their home. Chat with others, create a build thread, post questions and answers. Get involved! Logging in will also remove many of the advertisements, along with this notice. ;) It will also allow you to view images in threads.
Please Support RTM Racing
Flywheel run out
TK's9d2TSi
Supporting Member
5,311
2,422
Sep 11, 2017
Cincinnati, Ohio
I picked up a used oe flywheel and had it machined with correct step height. Bolted it up and torqued. Set up a dial indicator and this is what I am seeing. What are your thoughts?
@twicks69
I have runout of .004 and the thread below says .005 is the limit. Is that accurate?
pauleyman
DSM Wiseman
7,062
2,022
Nov 19, 2011
oklahoma city, Oklahoma
I would want to remove it and check the mating surfaces again. Even just a tiny bit of grit or rust right at the base may put in some runout at the friction surface
TK's9d2TSi
Supporting Member
5,311
2,422
Sep 11, 2017
Cincinnati, Ohio
Both are clean. I even carefully took a razor to the crank to remove the old thread lock.
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com Raven Fabrication RixRacing RockAuto RTM Racing STM Tuned VR Speed Factory
