ninjai_ruken
- 1,526
- 13
- Feb 1, 2004
Indianapolis,
Indiana
Ok guys, I wasn't sure where to post this as of right now as the gremlins are still up in the air. So drink some coffee, Listen to some headbanging music...sit back and enjoy the read.
As a side note, I did do a search both in Google and Dsmtuners. While I found people with Similar Issues none of them where identical and the fixes applied I have already tried.
Spring 2016
I was prepping the Flying Banana for a mild season in Denver. A few open track days, a few NASA Events in the Denver region. Fresh Oil, Spark Plugs, Cleaned her up, Cleaned out the Fuel Cell and put new foam in it. Fresh VP 103 Octane Fuel. I started her up and she ran great, took her around the block "I have Montana Permanent Plates for the car" and the car was running like a beast. Sounded good, full WOT was good everything was fine. Pulled it into the garage and parked it for the night. A couple of days later I went to start the car and she would not run. I eventually tracked the problem down to a bad EPROM within the AEM Series 1 ECM. So I sent it off to be repaired, as a precaution I replaced the CAS and a few other sensors with new ones including a new IAC. I got my ECM back with documentation that they were able to save the tune. "Doesn't matter as I have the file anyways." I install the repaired ECU, as I'm sitting in the drivers seat pressing the start button she acts like she wants to start so I give it a little gas. Car starts, everything looks good on my gauges. While I have the gas pressed and the car is sitting at about 2k rpm it just shuts off. This symptom keeps going but at this point with school, family and preparing to move at the end of the year I throw some fuel stabilizer in the tank and pull the car cover over her.
Two weeks ago,
I recently moved to Indiana after Christmas in order to work for a Professional IMSA Race Team, I decide to go out and see if I can find out whats wrong with the flying banana. Same Symptoms so once again I check for Air, Fuel and Spark. I have Air, Spark and fuel pressure remains good. I haven't had the opportunity to do a Compression Test as I have not found my tool yet. I also cant find my damn COM Cable for my Series 1 ECM so I can connect to the laptop and see whats going on..."I'm really getting sick of this old Tech" As I previously stated the car runs with the throttle depressed but then just shuts off as if someone cuts all power. I understand there isn't a lot of information to go on, But at this point I'm about to strip the car completely down and rebuild it. I would like to cut costs by not buying a Series 2 but if I have to I will. I'm thinking about trying to find someone to lend me a Stock ECM and plug that in. See if she runs then. The problem is finding the time to get all of this done. As its the Race season and I'm busy like 24/7 any ideas helps guys
Ty McBride
Team Leader/Owner
McBride Motorsports
Mechanic/Crewman
LAP Motorsports
PS Mods if this is in the wrong section please move it. Thank you
Posted from HTC 10
Spring 2016
Two weeks ago,
Ty McBride
Team Leader/Owner
McBride Motorsports
Mechanic/Crewman
LAP Motorsports
Posted from HTC 10
