No_Skillz
- 2,759
- 28
- Dec 8, 2004
Freehold/Morris,
New Jersey
Does anyone know the max size slim fan that will fit with the stock A/C fan? I'd go measure myself but my DSM is not on hand.
Just to answer my own question and as a reference to anyone who searches in the future:
A 12" fan is the biggest that will fit with the stock A/C fan. For total replacement, one 12" fan and one 14" fan are the largest combo that will fit.
This must vary abit from manufacturer to manufacturer, as I know there's no way you can mount a 14" SPAL fan on a stock height rad core, unless your mounting it off the core surface & it comes out past the end tanks. 13" is the largest SPAL you can run.
Yup. Anything over 12", and it's going to overlap onto the endtanks. And it's definitely not a good idea to set up fans like that.
Thanks for clarifying for me fellas. Just for my information, why is it a bad idea to overlap some of the fan on the endtank? This was what I was planning to do.
The airflow around the fan area will flow like a river, in that, it will take the path of least resistance. If you put a solid 1" gap between the fan and the radiator core, the fan will pull/suck the majority of it's air through that gap, and less through the radiator core.Thanks for clarifying for me fellas. Just for my information, why is it a bad idea to overlap some of the fan on the endtank? This was what I was planning to do.
Yes.Would a 12" spal fan fit with the other stock fan ok?
