Please Support ExtremePSI
F5M311ZPML Transmission
Elpizer2
70
Jul 31, 2022
Miami, Florida
What's the maximum torque for a F5M311ZPML Transmission? does it work for turbo FWD? 4G63t 1g
This transmission comes from a turbo diesel Mitsubishi Chariot that, as best as I can find, was rated at 93hp and 145 ft-lb. It's a bit low compared to the typical output of a stock turbo DSM (195hp and 200 ft-lb). They did use the same size flywheel as a FWD turbo DSM and the same diameter clutch of a turbo DSM. I'm not certain about axles.
Ignoring the axles, it would likely bolt up and move the vehicle with the right clutch and flywheel, perhaps even work for a reasonable amount of time under daily commuter duties. Without deeper investigation, I personally wouldn't use it unless I had no other options simply due to the lower power output of the engine it was originally paired with.
It's a direct bolt in minus axles, running one on my gst spyder currently. Axles are the same at the hub side but different at the trans side compared to the FWD/ AWD axles. You'll have to source gs spyder axles and axle seals if you don't have the axles with it already. But other then that bolt in affair.
But like Brian said don't use it unless you absolutely have to, it wont hold the power long at stock levels more then likely. I haven't got many miles on mine since installation so I can't chime in on how long it'll last......i litterly had nothing else.
