samnumba1
- 447
- 1
- Oct 6, 2004
South Georiga,
Georgia
Ok well I have done a lot of maintanence stuff latly... timing belt.. all seals.. valve cover gasket oil change radiator flush tranny flush and I had a bolt missing on my exaust manifold so I helicoiled it put a stock stud in and bolted back on the exhaust manifold ( with ALL new gaskets) I know there is a exhaust leak somewhere casue at idle no noise(no boost tring to leave) then I revv it up and the higher RPMs are the louder the humming. When I drive and I hit boost there is NO PULL AT ALL I just see boost go up and no power... so I need to find this leak because there is no carbon deposits or anything and I put my hand all over the exaust and couldnt find it at start up... or by what im describing is there an exact spot I should look at
thanx,
Sam
P.S. I torqued all the bolts down to spec throughout exaust... im thinking the manifold possibly bent while the screw was gone
thanx,
Sam
