nuclearr
- 1,410
- 13
- Jun 22, 2004
Slidell,
Louisiana
I can not get evo scan2.9 to work with my ceddy mod flashed ecu. I put the xml file ceddy provides into the datta setting files but when i open evoscan it tells me that some thing are duplicated. Also ceddys file does not show up in the edit datta settings pull down once in evoscan. then when I try to logg it tells me that almost every thing is duplicated tps injector scalling latency and much much more it tells me I must rename one of every option.
