2G EVO IM sparkplug wires
Please Support Rix Racing
Bedicine
442
149
Jan 3, 2022
Toronto, ON_Canada
Just curious for anyone that has a 2g and running an evo3 intake manifold. What wires (mainly length not brand) did you go with when mounting the ignition coils using the evo3 factory location on top.
I know 2gs are a bit longer so would the 1g wires be the best choice for length if the coils get mounted on top? I’ve got a BF evo 3 bracket coming but just trying to decide what would be the cleanest, planning on running a cover over them so would need to use the Chanel for the wires and not go over the top.
Thank you
1g is longer NOT shorter then 2g, i use 1g myself as i run the wires under the IM.
You could order Evo 3 spec wires and stay the same location but alot remove the mount as its vertical and was known to trap water/moisture in facing up.
Evo and 2G wont be far apart length wise
Oh good to know. Do you have a photo of how yours sit?
If I have coils from a 95-99 would the evo 3 wires fit?
Not sure if i got pics of it greatly shown. I shall look later on though.
If you have it in the stock evo 3 location the 2g wires will be plenty long enough
Coming from a guy with an Evo 1, what’s wrong with the OEM Evo way of doing things? It will look clean and there are kits available.
You can always shorten them if you’re not happy with the length. That’s what I did.
Relocate the coil pack under the intake manifold and use 1g wires, don't see anything :)
It's not about the coils, it's about what intake manifold and coil bracket you use.
If you meant that 2g stock coil location on 2g stock intake manifold, a bit short but yes the early EVO wires would fit. It would be like the 1st pic below. The 2nd pic is with EVO 1-3 intake manifold w/EVO 1-3 coils.
The pics show Nagai-Denshi spark plug wires. The part number is 2557-10 for Red and 2557-20 for Yellow.
I use the rtm coil bracket with 2g wires. But plan to relocate to stock evo1-3 or move to under manifold.
