twisted69
- 35
- 0
- Aug 31, 2003
New_HampshireUS
i have heard that the evo 3 16g is a bit bigger then big 16g. i was wondering if the evo is a direct bolt on and need no extra parts. this is for a 1g gsx eclipse
Note: This feature currently requires accessing the site using the built-in Safari browser.
I can't imagine why it wouldn't. The only thing that makes the DP not fit exactly is the Evo O2 housing. You can use a Evo III 16g with your stock O2 housing (ported like hell, I hope) and your DP will fit fine. If you put an Evo O2 housing on a T25, you will need a new flange welded on your DP to make it fit or buy an RRE (or any other manufacturer that does it) DP that's made to fit the Evo O2 housing.So if I were to get a Evo 3 Turbo and the install kit it won't bolt straight up to my turbo back 02 eliminator exhaust?
Originally posted by Chadillac2000
so would the evo316g mate up fine with a 3 inch rnr dp with an 02 elim?
