Lano91
- 0
- Mar 31, 2019
osl,
Europe
Hello,
I am currently in the middle of converting my 1996 GS (european version with 4g63 nt engine) to turbo by swapping in a 4g63t from a 1999 GS-T, and im in need of help.
Some background;
Swapped in a 4g63t engine from a 1999 gs-t. I decieded to use my old NT wire harness from the 96. I've added in the extra wires for the turbo application such as MAP sensor, knock sensor, injector resistor wiring and boost gauge.
CAS seems to be on the same side on both engines, and the harness did both plug in the same sensor.
The engine is from a 1999 gs-t. The ECU is from the same 1999 gs-t. The engine wiring harness is from the 1996 nt with added wires to accomodate turbo applications.
After doing the swap, the car would not start. When turning the key, i can hear some sort of clicking noise? there is no crank at all. Lights and instruments seem to turn on as usual. A new battery is currently installed in the car.
Could somebody please guide me with troubleshooting? No idea where to start. I am thinking it might be an electrical issue?
Some background;
