engine transplant in my mom's caravan. need help
Status
Not open for further replies.
500hptoyotaecho
Apr 22, 2003
hey my name is bobby . im 12 years old. my parents are away on vacation and since im getting the 94 caravan when i turn 16 i want to hook it up. i bought a 5.0 liter mustang engine from a friend who found it in his dad's garage. he's 16 and helping me put the engine in our caravan. he doens't know much about cars as me though.
question is how long do u think this will take. what problems might i run into. i have to finish this soon b4 they get home.
thanks
VERY easy to do, it is procticalyl a drop-in mod. I did this a few eyars back and let me tell ya. That thing was smokin!
You have a little machining to do with the motor mounts, but in general it's a pretty common, straight-forward swap.
As a great coincidence, the injectors are almost all the same, and believe it or not, the caravan ECU will run the 5.0
It will only run on 6 cylinders though, but if you don't have the 5.0 ECU, that will have to do.
If you've ever installed an aftermarket CD player, that's about all the wiring harness issues you'll do.
*Aren't you on the wrong forum?
wait i thought DSM stood for Dodge Speed Minivans? doesn't it.
maybe im wrong. sorry. but so it should be easy then. ok im goin to try to disconnect the engine now. ill post later
Make sure you post some dyno results when this beast is finished. I can't wait :thumb:
Since that will be a fast swap, have you considered a body kit?
My uncle has a nice custom kit for his van, i can get the brand if your interested.
Status
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
