Engine problems
flames
Oct 18, 2010
Houston, Texas
my bs belt snaped and it was brand new. now all my rocker arms just fell off, do you think my engine is done? i see no signgs of valves hitting the pistons threw the spark plugs holl like when my timing belt snaped on me a while back. now only the bs belt snaped and my timing is looks intacted. heelllppp please?
Having a hard time comprehending exactly what your saying.
Most likely cause that your rockers got launched out of place is from catastrofic valvetrain to piston contact... Hope this helps.
You can try to reinstall the rockers by the method found here. Then turn the engine over by hand and attempt to line up the timing marks checking for interference. Or you can pull the timing belt like you are going to do a normal timing job (you can do the balance shaft belt at that time as well), reinstall the rockers the by pulling the camshafts, reinstall the timing belt, and try turning the engine over by hand to check for interference. Usually when rockers are thrown off, it means bent valves due to jumped timing.
