Heartless
- 99
- 2
- Jan 18, 2007
MTV,
Ohio
Ok, I had a cracked block after rebuilding the engine, getting coolant in cyl #1. Got a new block using the same head except L-19's instead of standard ARP's, had it bored, honed, decked and surfaced for an mls headgasket. (used Mitsu MLS 4-layer) Now Cylinder #2 only has 90psi. So, I changed the headgasket and used a power enterprise mls, cyl #2 still has 90psi!!! If you add oil, doesnt change at all, leak down test shows nothing! Pressurized the cylinder, blocked off everything and the air didn't come out anywhere! no coolant in the oil or vice versa. It just doesnt make sense when cyl 2 was fine in the old block and now it has low compression! Both head and block are straight, and surface for an mls, brand new bc springs and retainers, SS valves, 3-angle valve job, ect. Anyone have any suggestions?
