91Bomb
- 909
- 7
- Jul 15, 2003
US,
New_Jersey
I had a little clattering noise since I changed the timing belts a couple moths ago that sounded like it could be a valve clattering, engine or balance shaft bearing going out etc. I also thought maybe 1 balance shaft wasn't lined up exactly although rear BS is definitely in phase. Anyway since car has 213K mi with original everything I wasn't too worried about a little noise but tonight it got much louder after running it hard and then engine shut off and something is seizing up becasue the tires chirped (m/t) as it shut down in 3rd or 4th gear while driving normal. Then even though battery is 100% good car didn't want to crank at all as if something was seizing up. After waiting awhile it did crank but just barely and then after waiting even longer it started and I drove it home 3-4 mi with the clattering which is much louder than it had been for prior 2 months. It's not super loud or horrendous sounding either but something is definitely wrong and felt lucky to make it home. Oil on stick looked good and no overheating with good coolant level and I just changed oil a few days ago which didn't have any metal in it. Where should I look first for problem?
