1. Join the Community!
2G Engine Flipped Inline w/ Driveshaft?
Posted by Kai Hefner, May 15, 2020
Please Support STM Tuned
Please Support Rix Racing
  1. Kai Hefner
    Kai Hefner Freelancer
    303
    158
    Joined Jun 21, 2018
    Calgary, AB, Canada
    I feel like I've seen it before and I'm just doing a bit of research out of curiosity. Is there a write-up or info on someone flipping our engine to be inline with the driveshaft? Same orientation as the mighty-max I believe. Just want to become informed because I'm looking at a similar idea myself.
    Road Race Build 890  2
    1998 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
  2. Steve93Talon
    Steve93Talon Proven Member
    1,465
    104
    Joined Jan 20, 2005
    Philly Burbs, Pennsylvania
    Drag Race Build 1K  24
    1991 Eagle Talon TSi AWD
    369.5 whp · 403.2 lb/ft · 1G DSM
    2K  7
    1993 Eagle Talon TSi
    11.784 @ 115.120 · 1G DSM
    Loading...
  3. Kai Hefner
    303
    158
    Joined Jun 21, 2018
    Calgary, AB, Canada
    This website has a ton of great info! Thank you. Not much about fitting stuff in a 2g. It's nice to know the stuff about the rx7 trans but what I'm most concerned about it engine mounting solutions, trans-tunnels and driveshafts.
    Loading...
  4. ThunderChild
    ThunderChild Supporting VIP
    2,942
    1,007
    Joined Jan 5, 2012
    Rathdrum, Idaho
    It will all be custom.
    You'll have to cut the tunnel to fit a trans, fab f new front cross member, mounts, possibly front suspension modifications etc.
    Not a light-hearted undertaking, lots of custom fab fab work.
    Street Build 705  3
    1990 Plymouth Laser N/T
    fwd · manual · 1G DSM
    696  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 1K  7
    1997 Mitsubishi Eclipse Spyder GST
    fwd · manual · 2G DSM
    2K  0
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Street Build 3K  10
    awd · manual · 1G DSM
    Loading...
  5. OH91awd
    OH91awd Proven Member
    802
    416
    Joined Sep 22, 2011
    chillicothe, Ohio
    kevin jewer would be the perfect person to talk to on that. he own sigma six tuning as well as marion county raceway in ohio. he has a rwd converted 1gb so its right up your alley.
    Drag Race Build 2K  17
    10.89 @ 125.67 · 1G DSM
    Loading...
  6. Kai Hefner
    303
    158
    Joined Jun 21, 2018
    Calgary, AB, Canada
    What's his DSMTuners tag? If he has one... essentially the point I'm trying to get across is that I might want to go RWD on one of the cars, but taking out the front axles and buffing the rear just doesn't feel proper enough.
    Loading...
  7. Ludachris
    Ludachris Founder & Zookeeper
    3,774
    1,291
    Joined Nov 12, 2001
    Roseville, California
    @95GSXracer ;)
    He's tagged. Hopefully he'll come in and reply.
    Street Build 9K  0
    1997 Eagle Talon TSi AWD (sold)
    manual · 2G DSM
    Road Race Build 8K  10  23
    1991 Mitsubishi Eclipse GSX
    435.0 whp · 399.2 lb/ft · 1G DSM
    Loading...
  8. 95GSXracer
    95GSXracer DSM Wiseman
    1,372
    129
    Joined Jul 25, 2002
    LaRue, Ohio
    Converting a FWD/AWD car to RWD is a lot of work, and in my opinion not necessarily worth the trouble. It requires a lot of cutting and fabbing, creating structure where there isn't any, coming up with some kind of front suspension (the front K member has to go away) and steering, etc. You can spend a lot of time and money here.
    On the other hand, if you start with any other RWD vehicle, 90% of that work is done for you. It already has a front suspension and steering system that works, rear axle and related structure, etc. Considering a Mighty Max as an example, it's really just a motor/trans swap at worst, wiring, etc.
    I'm not sure if this helps or not. In the meantime, here is a random pic of the front end of my car. It's a Strange Ultra Strut deal with a typical manual racing rack. You can also see the mid plate setup, trans tunnel, etc.
    Drag Race Build 3K  5
    7.961 @ 171.10 · 1G DSM
    Loading...
    Steve93Talon and Ludachris like this.
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
