engine differences
Yes 91's are 6 bolts it is either the late 92's or 93's that they went to 7bolts.. you can tell my looking at your oil pan.
that and I dont think there were to many AWD"s that didn't come turbocharged but i could be wrong there... so although there wouldn't be any deference in the engine if it is turbocharged there would likely be a deference in the cars ECU and duh the turbocharger. and the boost gauge in the dash etc.
no AWD's came w/o a turbo --
its 91 1/2 + that went to 7bolt
awd/fwd motors are the same
yea look at VFAQ they tell you what to check for on the oil pan, there is a bump that goes into the pan on one of the two and i think is extruded on the other.. just look at the VFAQ page it can tell you how to check.
  • For sale 2g Rear o2 sensor
    2g eclipse rear o2 sensor
    • Dryppical
  • For sale 2g Valve body
    2g eclipse valvebody and solenoids
    • Dryppical
  • For sale 2g Act throw out bearing
    • Dryppical
  • Wanted 2g Eclipse ignition actuator pin
    You must be registered to see element.Looking for this pin that goes into the ignition assembly...
    • Markhamx
  • For sale 2g Ac bracket
    2g eclipse ac bracket
    • Dryppical
