1. Join the Community!
1G ECU Questions
Posted by 1g_talonman, Apr 22, 2019
Please Support STM Tuned
Please Support VR-Speed Factory
  1. 1g_talonman
    1g_talonman Probationary Member
    28
    7
    Joined Sep 20, 2018
    Saskatoon, SK, Canada
    I have a '91 Talon TSi AWD automatic with turbo. I'm needing to buy a new ECU and would like some clarification on which ones I'm able to use.
    From my understanding:
    •The difference between 1g and 2g does matter
    •The difference between naturally aspirated and turbocharged does matter
    •The difference between AWD and FWD does not matter
    •The difference between standard and automatic depends on your setup
    The previous owner has put 450cc injectors as an upgrade from the stock 390cc, and I haven't checked yet but I'm going to assume he changed the fuel pressure regulator as well. As a result, he put a '90 turbo s/t ECU (part MD145903) in the car. If research serves me correct, this means that pins 6 and 14 were swapped as would be needed to put a '90 ECU in a 91-94 car.
    I have more details on this in my build thread, post #10 to be specific. I've checked the diagnostic port and got a constant reading which would mean the ECU is being reported as faulty.
    Anyway, some clarification on which ECUs I'm able to use would be appreciated. Thanks.
    Street Build 414  6
    1991 Eagle Talon TSi
    awd · automatic · 1G DSM
    Loading...
    Featured Products from our Supporting Vendors
  2. dustyboner
    dustyboner DSM Wiseman
    907
    355
    Joined Mar 13, 2016
    abq, New Mexico
    https://www.dsmtuners.com/threads/1g-dsm-ecu-compatibility.476966/
    1g Eclipse ECU Part Numbers
    -Electronic control unit
    (’90)
    AWD w/Calif ECS – MD145902
    AWD w/o Calif ECS – MD145903
    FWD 2.0L Normally aspirated w/Calif ECS – MD128622
    FWD 2.0L Normally aspirated w/o Calif ECS – MD128624
    FWD 2.0L Turbocharged w/Calif ECS – MD128623
    FWD 2.0L Turbocharged w/o Calif ECS – MD128625
    1.8L SOHC w/Calif ECS – MD120845
    1.8L SOHC w/o Calif ECS – MD128658
    (’91 to ’92)
    AWD auto trans w/Calif ECS – MD165532
    AWD auto trans w/o Calif ECS – MD165531
    AWD manual trans w/Calif ECS – MD166263
    AWD manual trans w/o Calif ECS – MD166262
    FWD 2.0L Normally aspirated w/Calif ECS – MD166256
    FWD 2.0L Normally aspirated w/o Calif ECS – MD166255
    FWD 2.0L Turbocharged auto trans w/Calif ECS – MD165530
    FWD 2.0L Turbocharged auto trans w/o Calif ECS – MD165529
    FWD 2.0L Turbocharged manual trans w/Calif ECS – MD166261
    FWD 2.0L Turbocharged manual trans w/o Calif ECS – MD166260
    1.8L SOHC w/Calif ECS – MD159562
    1.8L SOHC w/o Calif ECS – MD159561
    (’93)
    AWD auto trans w/Calif ECS – MD193296
    AWD auto trans w/o Calif ECS – MD193300
    AWD manual trans w/Calif ECS – MD193295
    AWD manual trans w/o Calif ECS – MD193299
    FWD 2.0L Turbocharged auto trans w/Calif ECS – MD193294
    FWD 2.0L Turbocharged auto trans w/o Calif ECS – MD193298
    FWD 2.0L Turbocharged manual trans w/Calif ECS – MD193293
    FWD 2.0L Turbocharged manual trans w/o Calif ECS – MD193297
    (’94)
    AWD auto trans w/o Calif ECS – MD304485
    AWD manual trans w/o Calif ECS – MD304484
    FWD 2.0L Normally aspirated w/o Calif ECS – MD304481
    FWD 2.0L Turbocharged auto trans w/o Calif ECS – MD304483
    FWD 2.0L Turbocharged manual trans w/o Calif ECS – MD304482
    Bud92gsx likes this.
  3. 1g_talonman
    28
    7
    Joined Sep 20, 2018
    Thank you, I'll be sure to read through that thread. The search function is kind of iffy, that thread did not show up for me :ohdamn:
    Street Build 414  6
    Loading...
  4. EVLGSX
    EVLGSX Proven Member
    332
    129
    Joined Dec 7, 2017
    Wallingford, Connecticut
    I usually search dsmtuners right from google. seems to get better, more relevant results
    Street Build 1K  15
    1997 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
    AlmightySo likes this.
  5. 1g_talonman
    28
    7
    Joined Sep 20, 2018
    Good tip.
    Street Build 414  6
    Loading...
  6. dustyboner
    907
    355
    Joined Mar 13, 2016
    abq, New Mexico
    site:dsmtuners.com :thumb::thumb::thumb::thumb::thumb:
    Screenshot-2019-4-22 brian earl spilner site dsmtuners com - Google Search.png 6252.gif
  7. Bud92gsx
    Bud92gsx Proven Member
    7,960
    80
    Joined Jan 16, 2008
    Wisconsin, Wisconsin
    I havnt seen the build thread. But the mods seem legit if he used the mt ecu.
    You guys don't love the new search.LOLz
    4K  13  14
    1992 Mitsubishi Eclipse GSX
    13.300 @ 102.400 · 1G DSM
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned VR Speed Factory White Shed Speed
