Chris1990gsx
- 56
- 0
- Jun 15, 2012
Longbeach,
Mississippi
I have a 1990 gsx im loooking to up grade to Eprom i was wondering if anyone know of anygood deals to buy it at.
Thanks
Thanks
hmmm, your ecu should be an eprom if it is the original one...have you checked it?
Incorrect. Not all 90 turbo ecu's are eprom, just like not all 91-94 turbo ecu's are eprom.
Thanks
^It's more simple now..It only takes swapping 2 pins.
That was my reaction as well. ^^
You have to swap 6&14 to get the car to run properly. A small board must be added to a 91-94,ecu for the tach to work properly in a 90.
Keydiver isn't making the tach adapters anymore but there may still be some floating around. (I have a couple left) It's the simplest way to deal with the incompatibility between the 90 gauge cluster and the 91+ ECUs.
If you want you tach to work right it is more involved than swapping pin 6 and 14.
Steve you should really do a write up on this..Everytime I see this come up..It's always swap those pins..Unless I forget to recheck the thread.
Donnie explain a little.more ###.
We.swapped a 94 ecu into my car yesterday and it ran fine. Even got a tach signal they were just a bit off.
Steve so I was right in mu earlier post about having to swap the tr units etc.
Bleh! I thought it was gonna be easy.
Featured Products from our Supporting Vendors
