1. Join the Community!
Ecmlink Tuning
Posted by 95tsiawd0330, Feb 26, 2012
Please Support VR-Speed Factory
  1. 95tsiawd0330
    95tsiawd0330 Proven Member
    129
    Joined Feb 9, 2012
    woodlyn, Pennsylvania
    can someone look at my stream from when i had my laptop on my car with the ecmlink v3 and tell me what you see wrong with it please help me tune it in
  2. 95tsiawd0330
    129
    Joined Feb 9, 2012
    can i get some help on telling me if all my settings are good like fuel trim airflowperrev ect..... if not can someone give me a step by step on what to do iam new to dsm cars and would like to learn how to set my own car up instead of paying someone 450 dollars to tune it
    my mods to my car
    6 bolt swap with 7 bolt head,ross forged pistons 8.5:1,eagle crank,eagle rods,acl bearings,arp head studs,crower valve springs,ngk plug wires,fic 880cc injectors,walboro255lph low pressure fuel pump,evo3 intake manofold,evo3 16g turbo,fp exhaust manofold,90throttle body,godspeed fmic,fipk intake,90 oilcooler,megandump 02 housing,3inch dp with cat delete,3inch megan catback,3inchthermal exhaust,aem wideband wired as the front o2 senor,dsmlink v3,greddy bov,hallman pro boost controller
  3. 96WhiteTSi
    96WhiteTSi Proven Member
    106
    4
    Joined Mar 6, 2009
    Reno, Nevada
    You are better off going to
    http://www.dsmlink.com/forums/
    and ask there for help... Nothing against the guys here... just thats the LINK specific site...
    647  0
    1996 Eagle Talon TSi AWD
    manual · 2G DSM
    Loading...
  4. ladsm88
    ladsm88 Probationary Member
    Joined Feb 12, 2012
    North Hollywood, California
    or email thomas doris from ecmlink so you can get a straight forward answer.
  5. skatershawn
    skatershawn Proven Member
    934
    11
    Joined Feb 27, 2009
    Austin, Texas
    Or watch these videos:
    ECMTuning, Inc.
    I'd take a look but im on my phone right now, in bed! If you can't figure it out still after these video's ill take a look and see if my knowledge is helful. Fyi im still new to tuning via dsmlink.
    870  5
    1993 Eagle Talon N/T
    fwd · manual · 1G DSM
    Loading...
  6. gofer
    gofer Moderator
    5,509
    1,026
    Joined Feb 18, 2006
    South Gilbert, Arizona
    It probably wouldn't hurt you to watch EVERY video here. ---> ECMLink Demo Vids
    Then read through this. ---> ECMLink Wiki
    Then, once you've done ALL of that you'll have to post a log (after following the videos) for us to tell you if you're doing everything correctly or not.
    :dsm:
    Street Build 18K  13  61
    1997 Mitsubishi Eclipse GST
    11.634 @ 126.050 · 2G DSM
    3K  0
    1997 Mitsubishi Eclipse N/T
    manual · 2G DSM
    Loading...
  7. 95tsiawd0330
    129
    Joined Feb 9, 2012
    i have watch the videos and read wiki i just would like to get someone that been messing with dsm cars to just look at my logs.
    i just would like to know what values i should be at i know airflowperrev should be at around .25 and i noticed in the video the mans 02 sensor was going up and down fast my 02 was not
  8. snowborder714
    snowborder714 Moderator
    12,079
    244
    Joined Oct 15, 2006
    Mechanicsburg, Pennsylvania
    So do you have a narrowband simulation wire input into the front o2 sensor, or is it a wideband output? I'm confused how you have narrowband sim setup, but no wideband input for the sim to utilize. Get that corrected first.
    Then watch video #8 from the links that were provided (even if you already have) and replicate the steps at idle after your car has warmed up. Your AirflowPerRev and CombinedFT values are off.
    Then post an idle log once that's all done.
    3K  0
    1995 Mitsubishi Eclipse GST
    12.529 @ 110.820 · 2G DSM
    Loading...
  9. 96WhiteTSi
    106
    4
    Joined Mar 6, 2009
    Reno, Nevada
    If you dont know why his was going up and down fast and yours is not.. then you have not watched the videos and read the wiki in its entirety..
    You really need to watch those videos and read the wiki.. ALL of it that applys to you (if your not running SD then skip that section)
    They help... no one here or on link forums are gonna TUNE your car for you... for free at least...
    you can always contact this fella...
    Remote Tuning,Custom Eprom Chips,Ecu Services - DSM Classifieds
    647  0
    manual · 2G DSM
    Loading...
  10. 95tsiawd0330
    129
    Joined Feb 9, 2012
    Iam not understanding you snowborder?I know i have a aem wide band that runs into a white wire of my ecu is this what you mean?If not sorry iam just new to all of this.I just got the car
  11. gofer
    gofer Moderator
    5,509
    1,026
    Joined Feb 18, 2006
    Yes, but which white wire? There are two that are side by side, one to the front o2 sensor and the other the rear o2 sensor input.
    :dsm:
    3K  0
    manual · 2G DSM
    Loading...
  12. jrohner
    jrohner Proven Member
    2,557
    9
    Joined Sep 25, 2004
    Willmar, Minnesota
    This is the most basic of all concepts for closed-loop tuning, if you don't understand this you really need to learn more before doing a lot of tuning.
    If your o2 is cycling up and down, your in closed-loop mode, meaning the ECU is controlling the fuel based on feedback from the o2 sensor. If the o2 is not moving you're in open-loop, so the ECU is ignoring the o2 and fueling based on the fuel maps. At low loads, if it's not cycling, then your fueling is way off most likely; on a narrowband, higher voltage means richer.
    2K  0
    1991 Mitsubishi Eclipse GSX
    11.415 @ 119.59 · 1G DSM
    4K  0
    1998 Mitsubishi Eclipse GSX
    414 whp · 459 lb/ft · 2G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
