alexr254
- 285
- 99
- Jun 18, 2021
Palm Coast,
Florida
First I do apologize for being such a noob, but I am so confused as to what I should do.
I truly am trying to learn and understand. It’s just a lot to take in.
At first I thought with the ECMLinkv3 ECU the AFR was being captured and displayed via software.
Now after more research looks like I was way off.
I am in the infant stages of a 99 Spyder 4g64t project.
I am confused as to what to do about the AFR sensor (wideband?).
I am trying to understand wiring and placement of the gauge as well as which sensor to get.
Also am wondering if there are any other gauges I should look into? Those pillar bands usually have space for 3 gauges, I don’t know yet what I would fill them with?
It’s dumb I know.
Placement wise, can I use one of those gauge pillar bands in a Spyder? Or is there a better option?
Does this wideband sensor replace the front O2 sensor? Will that not cause a constant CEL? If yes, is there a bypass?
Is there a popular go to wideband gauge/sensor I should get that works well with ECMLink?
So far based on what I’ve found via searches a lot of people have recommended this one.
Is this still the case?
The 6-8 week wait sucks. But if this is worth it I don’t mind waiting.
I am doing the DOHC swap. But am still undecided on which turbo to get, considering I will be sticking with the stock 4g64 pistons. (I know not great, but kinda need to for now).
It’s dumb I know.
SM-AFR Gen4 Wideband AFR with 2 1/16'' Gauge Combo
Accurately measure your car's wideband air/fuel ratio. Daisy-chain up to 16 sensor modules to connect with PLX Multi Gauges.
www.plxdevices.com
