turbakias
- 2
- Nov 1, 2019
Nea Artaki Greece,
Europe
Hi guys,
My name is Dimitris and i am from Greece.
Two days ago i purchased an eclipse 1gen turbo. The reason that i bought this car is because i liked it very much from the first time i saw it and second i needed a toy to play with.
My goal is to max engine horsepower with stock internals and change all periphereals needed for this purpose. I want to drive it sometimes a week for street race only.
I would like to have your opinions as i dont know much about this engine. I am reading the forum and have already found many useful info but i am a bit confused.
Let me share my thoughts.
Change exhaust manifold with a custom one with external v band.
Turbo gt3076
Downpipe and full exhaust 76mm de cat.
Iridium sparks and silicone spark plugs or coil on plug later
Injectors
Fuel pump
Bov
External 42mm
FMIC 65X30X10
Water radiator
Oil cooler
What do you think about these?
I would like to ask you your opinion for the following:
1) Are there any injectors from another car for direct fit for the horsepower i need? If not what cc you reccomend.
2) Do you think that with stock maf i can achieve such hp?
3) Is there any way to get rid of the maf? I assume stand alone ecu. Which one you reccomend that supports water methanol, launch control, anti lag, and other stuff?
4) Can electrics and sensors from evo8 as well as ecu can fit in this engine? Will it worth it?
5) Whats your opionion for the target i want to achieve?
Regards
Dimitris
Turbo gt3076
Injectors
Fuel pump
Bov
External 42mm
FMIC 65X30X10
Water radiator
Oil cooler
Regards
Dimitris
