Eagle rods, no more 6bolt rod bearings?
dyablo
250
Jan 22, 2005
Indio, California
Like the title reads, is this true? I just placed an order with extremepsi.com for some weisco pistons/ealge rods for my 7bolt and the sales rep. said no need for 6bolt rod bearings since ealge has changed their rods now. Went with weisco/eagle, cometic HG, arp main/head/rod bolts, acl .30 rod bearings, clevitt .10main and so forth. Just double checking as to what you guys knew about the new rods. And is it safe to put a new street disk into my act pressure plate? or do i need new clutch kit. Thanks.
well it was my understanding that earlier eagle rods required the use of 6bolt rod bearings:confused: . Thats what im trying to clear up with me.
As far as iam aware you use the normal 7 bolt bearings. At least eagle says on there site, I have also heard that it will say on the inside of the box also. I ordered some 3 weeks ago and my box says nothing on it.:thumb:
So is there a chance that the sales rep got his information wrong, telling me to go ahead and order 7bolt rod bearings? also is it safe to use a new street disk in the old pressure plate from act? I ask becuase after taking it the clutch apart the disk springs seems a bit loose.Id rather replace the disk now, then have to drop the tranny again. Cltuch and flywheel only have about 30k miles on them.
The only difference between the bearings is the width.
My 6 bolt Easgle rods, that I got 3 months ago, had a sticker that said to make sure to use the 6bolt bearings.
  • For sale 4G63 TD04HL turbo
    TD04HL turbo off a Mitsubishi RVR. This is a dsm bolt pattern turbo and is slightly smaller than...
    • MichaelSuch
  • For sale 1g 92-94 eclipse fender/door/quarter trim
    92-94 eclipse fender/door/quarter trim piece set. All clip towers intact. Passenger side quarter...
    • MichaelSuch
  • For sale 4G63 2GA AWD Auto Transmission
    2GA AWD Auto Transmission $750*** Pick up in 08080 NJ, you can also send a Freight carrier for...
  • For sale 4G63 70mm s90 throttle body - rebuilt
    Up for sale is a lightly used and correctly rebuilt 70mm s90 throttle body. This will fit all...
    • MindBlowin03
  • Wanted 4G63 1G JMF Intake Manifold
    Okay condition. Pm me with what you have.Ty.
    • oldkidken
