duel intake 1g
TsiTalon90
159
Dec 23, 2002
Granby, Massachusetts
ok i have a standard type hks filter and i'm thinking of running a duel in take. There is a k&n normaly and i'l thinking of cutting into the intake tube and running a second filter. is this sound ok?
no bashing
no bashing
for what.
While, I suppose you could begin by correctly spelling it "dual." That is, unless you meant you really want two filters fighting for air, which leads me to question why you'd want to do that.
well i'm going to use one regulary for intake (K&N) and the other for like ram air type thing. More air the better.
DUAL!!!
If anything just get an active hood scoop. I can't picture a two headed intake. Plus if you're brave enough to run one without a filter you might as well just open up the one you have now.
It's kind of a dumb idea but if you insist on doing it remember that new air filter/pipe has to go before MAF otherwise you'll be runing lean.
ya the more you say it, it does sound kinda dumb. i just wanted something cheap that would make the car faster.
air filter, feemods, Boost controler, Parkin light mods,
with those mods you should be looking at a down pipe and exhaust. UICP and inlet pipe. some silly double intake is pointless try some research.
Also I was too tired yestarday to think when posting. You can have 10 filters taking in cold air but it won't do any good with that snorkel right before turbo. Just get a nice big intake pipe from Dejon Tool and you'll be more then happy.
