CrackedDSM
- 5,833
- 5,729
- Dec 17, 2009
Pensacola,
Florida
Hey guys, I wasn't sure where this should go or how to title the thread, so forgive me double if this needs to be moved somewhere or if the title is confusing.
My question: How many people have the Dude's Custom Parts complete shifter rebuild kit? Doesn't matter what year.
My issue: After I installed the complete kit, it firmed it completely up and took all the slack out of it. That's not a problem, I enjoy how it feels. The Problem IS, it no longer will "spring" back or "return" back to center neutral(in neutral underneath third gear) in the cabin. It's not a shifter spring issue, because taking the cables off on the transmission and pushing down on the shift rod/assembly that goes into the transmission, mimics the same problem. It'll just stay down there. It's in neutral, it just doesn't "return" up anymore. This was not a problem before I installed the shifter bushing kit.
Does anyone else have this issue? Did you have this issue and it went away after they all broke in? Should I disassemble it and lube up the bronze bushings everywhere?
Real world experience is much appreciated!
Edit: here’s a pic of what I mean.
