TSITurbo95
- 17
- Oct 26, 2009
Ohio,
Ohio
If your wanting to use the ecu i would get one of our progressive controllers and map a 0-5v output and use our controller to do the pwm work. Then set the controllers 2 knobs to there min and max adjusment range and you can then adjust the voltage output of the ecu to get you the range you want.
Would this work with ECMLink's nitrous controls and disable meth on rev limit/in between shifts by using the 0-5v output?
