1. Join the Community!
DSM techs in NorCal
Posted by Londell Anderson, Jul 24, 2019
Please Support JNZ Tuning
Please Support STM Tuned
  1. Londell Anderson
    Londell Anderson Probationary Member
    Joined Feb 16, 2019
    Discovery Bay, California
    Does anyone know of a shop that has a DSM tech or know of anyone who has multiple years of experience working on DSM’s?
    lglracer likes this.
  2. Ludachris
    Ludachris Founder & Zookeeper
    3,702
    1,135
    Joined Nov 12, 2001
    Roseville, California
    @lglracer - any suggestions? I couldn't think of any place to send him.
    Street Build 9K  0
    1997 Eagle Talon TSi AWD (sold)
    manual · 2G DSM
    Road Race Build 7K  10  23
    1991 Mitsubishi Eclipse GSX
    435.0 whp · 399.2 lb/ft · 1G DSM
    Loading...
  3. lglracer
    lglracer Supporting VIP
    113
    29
    Joined Jul 13, 2008
    Sacramento, California
    The best place would be Overkill Performance.
    Road Race Build 526  1
    manual · 1G DSM
    Street Build 475  1
    1990 Mitsubishi Galant GSX
    awd · manual · Galant VR-4
    Street Build 1K  4
    1991 Mitsubishi Galant VR-4
    503  0
    1991 Mitsubishi Eclipse N/T
    manual · 1G DSM
    Loading...
  4. lglracer
    113
    29
    Joined Jul 13, 2008
    What is the issue you are having? If its something simple I may be able to help.
    manual · 1G DSM
    Street Build 475  1
    Street Build 1K  4
    503  0
    manual · 1G DSM
    Loading...
  5. Londell Anderson
    Joined Feb 16, 2019
    Where is overkill performance located? The problem I’m having is my car runs normal with an air fuel ratio of around 12-14 but as soon as I turn my air fuel ratio gauge it goes completely lean to around 16-18. My AFR gauge reads lean the whole time. Also my idle is off. I’ve checked for leaks and the ISC motor.
  6. lglracer
    113
    29
    Joined Jul 13, 2008
    Overkill performance is in Sacramento near arden area.
    Do you have your steering pump sensor hooked up. Thats the only thing i could see causing the car to lean out while turning. What software are you using and setup on,the car?
    manual · 1G DSM
    Street Build 475  1
    Street Build 1K  4
    503  0
    manual · 1G DSM
    Loading...
  7. Londell Anderson
    Joined Feb 16, 2019
    I do believe the power steering pump sensor is connected but I haven’t checked it for damage yet. I didn’t mean it goes lean when I turn, my apologies. It goes lean when I turn my AFR gauge on. It’s wired into the lights, so it comes on when the lights are on.
  8. lglracer
    113
    29
    Joined Jul 13, 2008
    @Wuino316 this is the guy near you
    Oh ok. So whats happening is that when,your lights come on the voltage changes. You need to tune the car for for that by adjusting your injector pulse time v voltage. What tuning software are you using?
    manual · 1G DSM
    Street Build 475  1
    Street Build 1K  4
    503  0
    manual · 1G DSM
    Loading...
  9. Londell Anderson
    Joined Feb 16, 2019
    I’m using ECMLINK.
  10. lglracer
    113
    29
    Joined Jul 13, 2008
    There should be a spot where you should be able to adjust the injector time,vs voltage in there. I would log them to,see what its doing.
    manual · 1G DSM
    Street Build 475  1
    Street Build 1K  4
    503  0
    manual · 1G DSM
    Loading...
  11. Londell Anderson
    Joined Feb 16, 2019
    There is a spot I forgot what it’s called but it allows you to tune for different voltages.
  12. lglracer
    113
    29
    Joined Jul 13, 2008
    Yep. I wish I remembered more of the ecmlink. I'm on a link g4 ecu.
    manual · 1G DSM
    Street Build 475  1
    Street Build 1K  4
    503  0
    manual · 1G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
