1. Join the Community!
1G Driver’s Side Axle Change-out
Posted by Mech Addict, Nov 2, 2019
Please Support VR Speed Factory
Please Support Feal Suspension
  1. Mech Addict
    Mech Addict Proven Member
    123
    51
    Joined Jun 9, 2019
    Jackson, Wyoming
    So all my front CV boots are completely torn in half. Highway vibrations and tight turn clicking are noticeable. Going to purchase new or rebuilt assemblies and change them out. I’ve read several posts on doing this, and read through the FSM and Haynes. Question: is there an easier way to remove the driver’s side T.J. Housing and put in the new one without removing the center shaft bearing housing? If that center shaft looks OK, why take it out? I’ve read that once you remove both center and left shafts together, they can be separated with some persuasion, and the new T.J. splined receiver can be coupled back w/o disassembling the boot (vs. how the FSM instructs, piece by piece with a press). Who’s got the magic tech on this?
    Street Build 431  6
    1990 Mitsubishi Eclipse GSX
    awd · manual · 1G DSM
    Loading...
  2. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    5,202
    2,535
    Joined Nov 14, 2013
    Independence, Kansas
    Man I would unbolt the lower control arm from the ball joint, unbolt the strut and swing it out JUST ENUF to get the axle to get out of the front hub. Of course remove the nut and cotter pin first. Then a quick snap with a flat bar will snap the coupler off the jack shaft. Then its just R&R.
    Anyone else???
    Street Build 4K  29
    1992 Eagle Talon TSi AWD
    14.74 @ 117.04 · 1G DSM
    1K  14
    690  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 956  7
    1998 Eagle Talon TSi
    fwd · manual · 2G DSM
    Street Build 6K  13  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
    Mello likes this.
  3. Cherry
    Cherry Proven Member
    198
    52
    Joined Jun 16, 2019
    Hull, Georgia
    I replaced both seals this weekend. The only difference is that I removed the 2 nuts and bolts from the shock and swung the hub out. It takes a little bit of work to get it out of the hub this way, but its literally 2 bolts and 3 nuts and you get get them out. Other than that its just how 1991TSI said. It took me like 20-30 minutes with replacing the seals.
    Oh, and put an oil pan under the trans where the axles go in because some gear oil might come out. Check the gear oil levels and add some if needed.
    Street Build 341  3
    1991 Mitsubishi Eclipse N/T
    fwd · manual · 1G DSM
    Loading...
  4. Murdertalon
    Murdertalon Proven Member
    250
    50
    Joined Jul 7, 2016
    East side, Washington
    I unbolted carrier bearing, pulled whole axel out put carrier in a vice and violently smashed axel with 4lb sledge. then replace the carrier bearing since it's apart.
    323  1
    1991 Eagle Talon TSi AWD
    Street Build 3K  24
    1995 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
  5. 1990TSIAWDTALON
    5,202
    2,535
    Joined Nov 14, 2013
    Boy I sure am thankful for my Harbor Freight press :thumb:
    Street Build 4K  29
    1K  14
    690  18
    Street Build 956  7
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
