1. Join the Community!
GVR-4 Drilling 2g head / oil mod
Posted by LumpyVR4, Apr 15, 2019
Please Support STM Tuned
  1. LumpyVR4
    LumpyVR4 Supporting Member
    41
    17
    Joined May 21, 2014
    Sydney, Australia
    Getting a 2g head CNC'ed for my new build. I was wondering if, while I'm getting the bolt holes taken out to 1/2 inch, whether it would be worth getting the shop to drill the oil hole out to 13mm to the depth of the oil feed, to give the head as much oil as it wants. I'm not worried about bypass oil ending up in the head as I'm fitting a Kiggly regulator. Thoughts?
    Street Build 421  6
    1990 Mitsubishi Galant VR-4
    manual · Galant VR-4
    Street Build 2K  0
    1992 Mitsubishi Galant VR-4
    Loading...
  2. ec17pse
    ec17pse Freelancer
    3,732
    1,638
    Joined Nov 1, 2008
    London, Europe
    I believe the issue is drain of oil not oil feed, so going bigger might allow more oil to drain but the amount wont be alot more, the newer 4G63 engines have more oil drains then we got so concentrate on oil return rather then getting oil to the head ok
    Road Race Build 10K  10  55
    1997 Mitsubishi Eclipse GST
    175 whp · 180.1 lb/ft · 2G DSM
    Loading...
  3. 007jimmy
    007jimmy Proven Member
    1,472
    100
    Joined Feb 27, 2012
    Levittown, Pennsylvania
    I have done this on my 1g 7 bolt head. I ported the teardrop to .120” tapering deeper to the stud hole along with undercutting the 6 bolt ARP stud. I was looking for max oil flow along with lowering the block oil pressure. (I have no squirters/BS.) Valvetrain is nice and quiet. Just make sure you clear the casting flash in all of the return holes. I have the kiggly unit as well. About 5k miles on this build so far and no issues
    Street Build 1K  25
    1997 Mitsubishi Eclipse GSX
    awd · automatic · 2G DSM
    Loading...
  4. LumpyVR4
    41
    17
    Joined May 21, 2014
    Sydney, Australia
    Definitely cleaning up flash to make it drain fast. Once lost the big ends on a 351 Cleveland due to all the oil being in the heads. Here is one of the drain holes when I pulled the head on the weekend.
    Street Build 421  6
    Street Build 2K  0
    Loading...
  5. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    5,044
    2,381
    Joined Nov 14, 2013
    Independence, Kansas
    I always painted my SBC oil galleys which helped oil return to the pan faster that it would on bare cast. Never had any flaking or problems. When I would tear one down, it was still orange inside like the day I painted it. Worked on those V motors good for oil return.
    Street Build 4K  28
    1992 Eagle Talon TSi AWD
    14.74 @ 117.04 · 1G DSM
    863  14
    1990 Mitsubishi Eclipse GSX
    awd · manual · 1G DSM
    622  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 845  7
    1998 Eagle Talon TSi
    fwd · manual · 2G DSM
    Street Build 6K  13  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
