Turbo Monk3y
- 571
- 6
- Oct 14, 2002
Orlando,
Florida
2g Fitment only
Ok I want a better 60 foot for the upcoming season. Street tires did not cut it with the 2.0L 35R setup and they def won't with my new 2.4L t67dbb setup.. I have a few options and I will list them. Anyone with experience please feel free to let your opinion out.. I noticed GaStroker is the only one here that has 255/50/16s on his 2g with some 16x8s +40. Anyone else ever try this? Btw his setup looks badass and does not stick out very far from the fenders. This is something that I want, I don't need to have my dsm look like a frogged out Mexican mobile...
1st off
My current wheels are 17X7 Konig Traffiks 15.1lbs with 225/45/17 Hankook RS2-z212s. Would putting on the BFG 225/45/17 Drag radials make that much difference? or should I go wider as the car will be driven on the street.
2nd
Rx7 wheels 16X8 50 offset + 10mm aluminum spacers make this rim a +40 offset correct?. Will I need Longer wheel studs for 10mm spacers? If I got this rim setup I would be looking at getting the 255/50/16 bfgs
3rd Hunt down old Kosei K1s 16X8.5" 35 offset (unlikely to happen)
4th Who makes light 16X8 that look Decent.
5th Nitto 555R drag radials make a 245/45/17 But they recommend a 7.5" or wider wheel would these work with my 17X7s and not pose a saftey problem?
My car has a locked 50/50 center diff, an aluminum Driveshaft shop Driveshaft, and still running a Southbend Kevlar sprung Disk all to save the Shep Stage 4 and rest of driveline.
1st off
2nd
