99gst_racer
Moderator
- 12,009
- 1,695
- Apr 5, 2003
Coloma,
Michigan
its_hey_ma said:are my posts invisible or something? This is the 3rd time I'm posting to say I'm not downshifting above 5mph. I'm just talking about between like 1mph and 5mph. If its above 5mph I'll use 2nd but at 1mph 2nd just sucks and coming to a complete stop is even worse
At one or two MPH, you should be able to get it into first. If not, then you will either have to use second or come to a complete stop and then use first. I would recommend using second, esp. if your syncros are worn enough in the first place. As far as making a turn at under 5 MPH......
I thought only my grandma took corners like that.its_hey_ma said:well, im mostly doing the downshifting (when not at a stop) when i'm taking a corner at like 5mph
J/P. Where I'm from, any corner can be calmly taken in second gear because I'm usually going a little faster than 5mph.
