assault187
- 567
- 5
- May 16, 2005
Horsham,
Pennsylvania
I had installed a ACT 2600 kit with a street disc and lightweight flywheel a little while back but from the power the car was putting down the clutch slipped 3rd and 4th gear. I recently stepped up to the ACT 2900 with the street disc and new lightweight flywheel (I hate down time for somthing simple) All was installed and broken in properly but when downshifting, its a must to rev match for smooth downshifts. When not rev-matching (especially into 2nd gear from 3rd) the shake is violent when the clutch is engaging. Besides that all is well. Im sure its because it grabs soo hard but has anyone experienced the same problem?
yes my syncros are still alive and kicking. The problem only exists when the clutch is grabbing the flywheel so how do you figure double clutching will work? This is not a syncro issue with the trans, there is no grinding and it slides into each gear flawlessly..... Yes I am rev matching correctly....Thats why the problem will not occur when I rev match to downshift.
