GVR-4 Door Seal Clips
force_feed
323
4
Jan 31, 2008
Katy, Texas
Anybody know where to find the clips that hold on the door seals?
I've tried searching, but haven't found anything.
Thanks!
They were only sold with the weatherstrips. Try a body shop supply place, they may have something that will work.
Are you by any chance looking for something like this ?
Mitsubishi Weatherstrip Retainer 5mm x 13mm Head
You're welcome!
I bought the same part from JNZ pretty much at the same price, I needed it for the weatherstrip in the engine compartment, if it's not the same is very similar.
I should have checked, I verified CAPS, the one on the provided link is p/n MU481027 CLIP, HOOD 5.3 QTY 17 while the door weathestrip clip is listed as MB105489 CLIP, FRONT DOOR 5.2 QTY 60, it may be a snug fit by a 1/10 of a mm. I would call JNZ(or any other OEM vendor) and hit them with the part number and see if they have it, 60 of them. I tried the route of the JY and by the time I carefully removed the weatherstrip I had maybe 5 of those clips usable left.
Have bought these before from a local parts store. Just pull one out of your weatherstripping and take it in with you.
Sorry to bring up this old post, but I wanted to share what I found. clipsandfasteners.com sells this:
PAS9560-50 Weatherstrip Retainers - Honda​
which worked very well and fit great on my 1991 Eclipse's door's factory weatherstripping.
From these two pictures it looks like the Mitsubishi part number is an exact match to the Toyota part. I purchased 4 units from a Toyota dealer in order to confirm the match as the Toyota part can be had a little cheaper (approx 96 cents).
How are they holding up? They fit nice and tight in the hole? According to the graphic above it seems the stems are .2mm thinner than OEM. I know that's not much, but I figured I'd ask since I'm about to order some.
They are holding up perfectly. The weatherstripping and clips don't get much abuse, but they are certainly holding tight in the hole (in the door and the weatherstripping). I would not hesitate to order them if I were you - no issues even if they are not the original equipment size.
Where did you order them and how much are they? Ordering the Toyota ones I saved 40 cents each on the Mitsubishi price (if still available that is) but they still came at 93 cents each.
Just got the next attempt, a replacement for Honda 90664-671-0030. You can get them here: (for now)
or
These fit fine. (OEM but brittle cracked off barbs are yellow, replacements are white) The head is slightly longer and slightly wider, but the rubber stretches fairly easily. In the few holes that had minor splitting around the hole, it gave more support. They take a fairly firm push to get fully seated. The best news: A pack of 50 for $12. That's 24 cents each. Including shipping.
Thank you for updating the post with some good information!
Was Ebay the only place to find them, do you know?
