For 1990-1999 Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, and Galant VR-4 Owners
  • Join the Community!
Please Support Rix Racing
Please Support VR-Speed Factory
Door Seal Clips
force_feed
323
3
Jan 31, 2008
Katy, Texas
Anybody know where to find the clips that hold on the door seals?
I've tried searching, but haven't found anything.
Thanks!
hhuricane
306
4
Sep 16, 2009
Calgary, AB_Canada
They were only sold with the weatherstrips. Try a body shop supply place, they may have something that will work.
pauleyman
DSM Wiseman
6,448
1,671
Nov 19, 2011
oklahoma city, Oklahoma
No that's not true. They were available oem. I no lo ger have any but caps or asa should show the part number.
serviceguy
571
35
May 11, 2002
Clifton, New_Jersey
Are you by any chance looking for something like this ?
Mitsubishi Weatherstrip Retainer 5mm x 13mm Head
You're welcome!
I bought the same part from JNZ pretty much at the same price, I needed it for the weatherstrip in the engine compartment, if it's not the same is very similar.
I should have checked, I verified CAPS, the one on the provided link is p/n MU481027 CLIP, HOOD 5.3 QTY 17 while the door weathestrip clip is listed as MB105489 CLIP, FRONT DOOR 5.2 QTY 60, it may be a snug fit by a 1/10 of a mm. I would call JNZ(or any other OEM vendor) and hit them with the part number and see if they have it, 60 of them. I tried the route of the JY and by the time I carefully removed the weatherstrip I had maybe 5 of those clips usable left.
TunerJunkie
May 25, 2010
North, BC_Canada
Have bought these before from a local parts store. Just pull one out of your weatherstripping and take it in with you.
Kenneth Schlorf
90
9
Feb 15, 2015
Cottage Grove, Minnesota
Sorry to bring up this old post, but I wanted to share what I found. clipsandfasteners.com sells this:
PAS9560-50 Weatherstrip Retainers - Honda​
which worked very well and fit great on my 1991 Eclipse's door's factory weatherstripping.
serviceguy
571
35
May 11, 2002
Clifton, New_Jersey
From these two pictures it looks like the Mitsubishi part number is an exact match to the Toyota part. I purchased 4 units from a Toyota dealer in order to confirm the match as the Toyota part can be had a little cheaper (approx 96 cents).
01ce92206f99bdba0a61d4d3cb9025efd1.jpe
Paintballaa5
507
156
Jan 23, 2012
Houston, Texas
How are they holding up? They fit nice and tight in the hole? According to the graphic above it seems the stems are .2mm thinner than OEM. I know that's not much, but I figured I'd ask since I'm about to order some.
Kenneth Schlorf
90
9
Feb 15, 2015
They are holding up perfectly. The weatherstripping and clips don't get much abuse, but they are certainly holding tight in the hole (in the door and the weatherstripping). I would not hesitate to order them if I were you - no issues even if they are not the original equipment size.
serviceguy
571
35
May 11, 2002
Clifton, New_Jersey
Where did you order them and how much are they? Ordering the Toyota ones I saved 40 cents each on the Mitsubishi price (if still available that is) but they still came at 93 cents each.
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned VR Speed Factory
