Door Handle Installation ###HELP###
I'd say it was easy but it was kind of a pain fumbling around in the door. Take of the door panel itself, find the two screws holding the door handle on. One is beside the hinge closest to the lock, and above the lock mechanism. The other sits at an angle just below the other hinge. The lock is held on to the handle with a ring that fits on the lock and holds around the lock hole, just pry it off. Finally there is a plastic clip on the hinge closest to the lock that holds on to the metal rods. The clip on my old handle just popped off but my new one had a tab you had to pull to get it off. Take old handle off and start putting new one in, connect the metal rod to the clip on the handle, put the lock back in and attach the ring, then put both scres back in and put the door panel back on. Note it may be a little different in the 2g but I'm sure its close to the same.
ive. done it several times. its a little tricky, but not hard. you should get a friend to help you with the installation. you have to remove the door panel and the mirror, and all the bolts. take out the glass (otherwise you cant get to the handle) and switch out the handles and put everything back together.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
