DIY Denso COP (no CDI required)
So you want to ditch your 30 year old coils and plug wires for something cleaner, but don't want the issues that come with running 300m coils in wasted spark, or the problematic CDI's that tie in with the 300m COP.
The EVO community has been using Denso coils for COP with great success in 800+ hp setups with no CDI required. They're a cheap, reliable and comparatitvely powerful coil to the stock DSM coils, however these can eliminate the factory ignition control module, factory coil packs, and the spark plug wires all in one.
If you're looking for an ignition improvement over the factory DSM coil packs, chances are these are not going to improve over good OEM coils.
There are a few guys that have been successfully running these in DSM's, but I have yet to find a good guide on wiring them and having proper tach functions as you will be eliminating the PTU at the same time. I like the cleanliness of COP and I will say in comparison they are a better setup all around, I run a sparktech kit using the same coils on the 2.3/FP black in my EVO and have had zero issues with it the past 8 or so years it's been on there.
The reason these work so much better than the 300m coils is due to the fact that the 300m coils have to be wired in series to be properly fired by the factory PCM. Wired in parallel has too much load due to their resistance and will either blow up the PTU or blow up the driver in the ecu. Wiring them in series however drops their output way lower than they would be if fired sequentially. The Denso coils have a built in igniter so the computer doesn't carry any of the load of the coil firing, which allows us to wire them "sequentially" but still fire them as a wasted spark coil like stock.
Into the guide, what you'll need:
4x Denso coils - Prius coils are what SparkTech uses for their Evo COP, however almost any 4 wire Toyota coil will work fine as long as it's the same style as the Prius coils. In my pictures I'm using some random Toyota coil packs that I had laying at work. You're looking for this style ideally
Next you need 4x matching connectors- Spoolin Up used to sell these as pin your own kits, you can also find these online from various vendors. I pulled mine from a junkyard Toyota. Just make sure they're 4 wire and you'll be good to go.
Next you'll need a small length of wire or if you're cutting out junkyard connectors remove as much of the harness as you can with them.
Next on the list is either a junk 2g MAF, like I used, or if someone knows where to get a male PTU connector as a pin-it kit I'll gladly edit that in. I asked ECMTuning, Ohm Racing, and a few other manufactures on obtaining a male either 2g MAF connector or the PTU connector and none of them got back to me on it. The 2g MAF uses the correct connector and they aren't too hard to gut out of the MAFs housing.
You'll need to figure out a mounting plate for hold the coils. I traced a plug wire cover onto a sheet of aluminum and cut mine out with an angle grinder. The plate is setup for Prius coils, however, since I didn't have Prius coils on hand when I assembled it for testing I had to put some nuts under the coils to mount properly. As far as I know no one makes a plate for these off hand.
Wiring for these is fairly simple, we'll go back to the picture posted above of the connector to start.
On the Coil Connector:
Pin #1 is the 12v feed.
Pin #2 is a tach output signal.
Pin #3 is the trigger to fire the coil.
Pin #4 is the ground.
On the MAF/PTU connector: (you'll have 8 male pin slots in the connector itself, but only 7 legs on the back side. The 2g MAF doesn't use pin 8 so go to the side of the connector with the missing pin and mark it so you know which side is pin 8.)
Pin #2 - Combine Pin #3 for Denso coils 2 and 3, these 2 wires will run to Pin #1 of the MAF connector. Trigger B
Pin #3 - Combine all of Pin #4 wires off the Denso coils, they all run to Pin #3 of the MAF connector. Ground
Pin #4 - Combine Pin #2 from Denso coils 1* and 2*, these 2 wires will run to Pin #4 of the MAF connector. Tach Output
Pin #6 - Combine all of the Pin #1 wires off the Denso coils, they're all going to be run to Pin #6 of the MAF connector. 12v coil feed.
Pin #7 - Combine Pin #3 for Denso coils 1 and 4, these 2 wires will run to Pin #7 of the MAF connector. Trigger A
*Note: These wires are the tach output, if you combine all 4 coils together you'll have double the RPM reading on your tach. We combine 1 and 2 as they're on opposite banks of the firing order. You can combine 1/2, 1/3, 2/4, or 3/4 and still get the same accurate RPM reading, 1/2 are just closest to the connector and require the least amount of wiring. If you don't have these combined properly you're tach will not work properly.
I used crimp on connectors and then solder them to the MAF connector. This isn't the most ideal way to do this and where a pin kit would be much nicer. It is solid and works fine though for now.
Loom the wiring, plug everything in, test to make sure it runs on all 4 cylinders and the tach is reading accurate. Then you can remove both the stock coil packs and the ignition module and enjoy the new COP setup.
I'm currently using these on my 91 galant with a 210K mile stock 6 bolt with an FP red and supporting mods. I didn't have any issues with my original coils, but I like that I was able to ditch a couple fail points of the stock ignition system. There's definitely cleaner ways to orient these, but the angle on these specific coils made it a pain.
This should work on a 90 as well, however, you'll need a different male connector and the wiring is slightly different. My 90 is currently still tore apart in the back corner of my garage, but I do plan to update this guide with the proper 1990 wiring specs.
So how much have you tested this setup? My experience with some specific Denso coils similar to these is that this wiring setup can fail in unexpected ways. If you haven't tested this then I strongly suggest everyone take caution with this approach. Here's why.
My experience with similar Denso coils from some year Camry (I'm drawing a blank right now, but they look very similar to these) is that their maximum charge time is almost half of what a DSM ECU is hardcoded for (with exception of the black box ECUs as I think you can edit the dwell table there). My specific coils I found at 12V really could only tolerate a charge time around 3.2ms per their tech sheets, compared to the stock DSM charge time of I think 6.8ms? I forget, I have the dwell table somewhere.
What I found was when wiring my coils directly like you're describing let the car idle, and even drive at very low RPM, but as I started driving the coils stopped working (they completely stopped firing), yet would work after a power cycle (again, only idling, would crap out if I revved the engine). In the technical documents on my coils I found they had a failure mode that triggers when the coils are overcharged to prevent destruction/damage to the coils. What I realized was happening was as car RPM went up my voltage went up and coils were overcharging as my alternator voltage output was jumping above the idle voltage, and the dwell map was mapping out a dwell time way too long for these coils to tolerate at the given voltage. The stock dwell map as I pointed out is already way using a dwell time across the voltage range that is almost double what my coils are spec'd for, and honestly I'm surprised they even idled considering how far off spec this configuration was.
My solution was to develop a dwell reduction circuit, one that would intercept the firing trigger signal and delay it appropriately to map to the desired dwell times for the coils. This fixed my problem, and I've raced successfully on this setup for a few years now. Not something everyone is capable of doing and I turned over ownership of it to Spoolinup that produces Evo coil-on-plug systems as he sponsors me and provided the coils and wiring for me to play with.
I've driven roughly 4k miles on my setup. These are 2009 Yaris coils directly wired like the post reads. Not one issue so far. But if you would like for curiosity sake I can measure the dwell tomorrow morning.
What is the capability of these coils vs 300m with ARC2 box? I currently am on the 300m/arc 2 train at the moment.
I've never had good luck with the 300m coils and ARC on any customer car.
My experience with similar Denso coils from some year Camry (I'm drawing a blank right now, but they look very similar to these) is that their maximum charge time is almost half of what a DSM ECU is hardcoded for (with exception of the black box ECUs as I think you can edit the dwell table there). My specific coils I found at 12V really could only tolerate a charge time around 3.2ms per their tech sheets, compared to the stock DSM charge time of I think 6.8ms? I forget, I have the dwell table somewhere. What I found was when wiring my coils directly like you're describing let the car idle, and even drive at very low RPM, but as I started driving the coils stopped working (they completely stopped firing), yet would work after a power cycle (again, only idling, would crap out if I revved the engine). In the technical documents on my coils I found they had a failure mode that triggers when the coils are overcharged to prevent destruction/damage to the coils. What I realized was happening was as car RPM went up my voltage went up and coils were overcharging as my alternator voltage output was jumping above the idle voltage, and the dwell map was mapping out a dwell time way too long for these coils to tolerate at the given voltage. The stock dwell map as I pointed out is already way using a dwell time across the voltage range that is almost double what my coils are spec'd for, and honestly I'm surprised they even idled considering how far off spec this configuration was.
I've run this same setup in my Evo for 8 years with zero issues, along with the Evo guys that run the SparkTech and Spoolinup kits. The Prius coils share the same dwell as Mitsubishi. Couldn't tell you on the dwell of these random Denso coils but I can tell you they've held up fine to 24lbs of boost on my FP red. The normal Prius coils have been used by many people over the years without issue on DSMs, I'm by no means the first to do this, I just made a guide to do it since no one seems to know you can use these on DSM's for whatever reason.
Spoolinup's coils do not match the DSM non-blackbox ECU hardcoded dwell times.
I know this because we are good friends, my coils came from him, and we together worked on this little project of mine (he lives like 15 minutes from me). Also the Evos can adjust dwell times in their ECU to match and so any such issues are moot. That said, the fact that your coils work just fine on a DSM platform is great, and a wonderful simplification.
Wish I'd known before I dicked around so much with that dwell reduction circuitry. Thanks for sharing!
Spoolinup's coils do not match the DSM non-blackbox ECU hardcoded dwell times. I know this because we are good friends, my coils came from him, and we together worked on this little project of mine (he lives like 15 minutes from me). Also the Evos can adjust dwell times in their ECU to match and so any such issues are moot. That said, the fact that your coils work just fine on a DSM platform is great, and a wonderful simplification. Wish I'd known before I dicked around so much with that dwell reduction circuitry. Thanks for sharing!
All the Prius coils (as far as I know spoolin up is still using Prius) are 3.5MS at 12v and will alter some with RPM and voltage. DSM dwell varies from 3.5-6MS as modeled by ARC with their box. The Evo guys aren't altering dwell when installing spoolin up or spark tech coils. I can't say why yours didn't work but the Prius coils have been used in quite a few DSMs. The Evo uses the same dwell time as a DSM does, so I don't know what would've been different with yours.
Some of the LS coils people use in custom ignitions have a similar issue. If the dwell current is too high, they will fire prematurely to save the coil. The dwell reduction circuit you made is a good way to fix it. Lowering the voltage to the coils or a ballast resistor could do it too.
Keep in mind that apparently several people are improperly installing the coils nowadays. Comparing it to an improperly installed system isn't very meaningful.
There are a few threads where people talk about using 300M coils as COPs and wiring them in parallel. That is absolutely NOT the way to do it. And will cause misfires at even moderate boost levels. I tried to point it out in those threads, but they don't get it. The old COP kits were wired in series, and they worked fine.
Now if you want a COP setup that's comparable to OE (if not slightly better) and doesn't require a junk CDI, these Denso coils work great. If you're at the performance level of needing better than OE coils you're standalone computer should be capable of running coils better than any of these options anyways.
Wow haven’t been on this thread in a while. I missed a lot. Personally I have been using 300m coils not in parallel with ARC 2 box’s for years. I have used them up to and above 40psi of boost without issue. My car currently uses NGK branded 300m coils I wired myself with ARC 2 box. Well north of 30psi on a 62mm and 10:1 motor on e85. I also prefer to use BR8EIX for plugs and gap them down to .017. With this combo I have never had spark blow out issue again. Even as high as 40psi and north of 70lb/min logged. I am interested in these coils as a alternative when still using Ecm link sense dwell time is not adjustable with it.
Now if you want a COP setup that's comparable to OE (if not slightly better) and doesn't require a junk CDI, these denso coils work great. If you're at the performance level of needing better than OE coils you're standalone computer should be capable of running coils better than any of these options anyways.
Whether they are slightly better or worse than OE is probably going to depend on the application and condition of the existing components. But getting them to match the actual firing voltage of any of the available junk CDIs will be tough. Junk CD ignitions of all brands do a great job of creating high voltage. And the energy from these Denso's is going to be less as well. A junk CD spark will be more intense. So you should still be able to run larger plug gaps and have a stronger combustion start with the junk CD ignitions out there.
You should also check the wire seals on the brown connectors on the Galant install. Looks like they were mostly likely improperly installed, they shouldn't be sticking out of the connector that much. Fortunately that isn't high voltage, but that could cause a misfire if it was. The pic posted by talonman1200 looks right.
Wow haven’t been on this thread in a while. I missed a lot. Personally I have been using 300m coils not in parallel with ARC 2 box’s for years. I have used them up to and above 40psi of boost without issue. My car currently uses NGK branded 300m coils I wired myself with ARC 2 box. Well north of 30psi on a 62mm and 10:1 motor on e85. I also prefer to use BR8EIX for plugs and gap them down to .017. With this combo I have never had spark blow out issue again. Even as high as 40psi and north of 70lb/min logged. I am interested in these coils as a alternative when still using ECMLink since dwell time is not adjustable with it.
Using these on the 2.3 stroker/FP black in my Evo with stock dwell times for years. I run .024 gap on e85 with BR7ES copper plugs. Couldn't tell you logged airflow as I honestly have never cared to check it but no issues with no CDI and just these. My Galant is an FP red car on pump gas at 24lbs currently and BR6ES plugs at .028 gap. Same mileage as stock coils, no break up, were going to turn it up more here soon but I wont have issues i know that. Richard Montalvo with the Summit van has been running these on a 35R at over 40psi without issue for a few years as well, but he's on a Haltech. I know he's done a few installs on cars as well as he was selling them on facebook for a bit.
You'll have to talk to Toyota on those brown connectors since those came straight off a Prius in the junkyard like that, they suck so bad I still have no issues with these junk Densos.
I'm looking to jump to this on my 1G, Spoolinup setup.
How much psi are you running on this without spark blow out?
Spark plug gap?
Pin #1 - Combine Pin #3 for Denso coils 2 and 3, these 2 wires will run to Pin #1 of the MAF connector. Trigger B
Did you ever get the 90 wiring worked out? I have a 90 and want to do this.
I wanted to see if this would work on my 90 since I was going to do it same time as I planning to switch to a Cyclone manifold.
I gutted a PTU and used it as a connector and took the wiring off my old coil and the 90 Tach adapter. The car fired up but the Tach didn’t work. I used the same pulse that triggers the coils into the Tach adapter. I previously tried using the output from the coils and that didn’t work either. But it does at least run on a 90. Since I ended up sticking with the stock manifold I probably will stay with the stock ignition unless I can figure out the Tach signal.
Yes I know the wiring was 100%. I was just trying to flesh out the concept.
I got mine working. You will need a PTU. You have to tie the signal wires together and put a dummy load on it and use the tach adapter. I found the wiring diagram on another DSM site. I will see if I can find the information and post it here.
I can't find the information on the web. This is how I did mine. You will need a PTU. You tie your trigger wires to your COP and the PTU together. Then you take the PTU to coil wires and connect them to small relays. The relays have small coils in them. You take the other side of the relay and wire it to your tach adapter. The relays create a dummy load. Just wire them so they click and you should be good to go.
I know this is old but I have used this coils for a while and they do work like they supposed to. I have a friend that use them as well without any issues, so I end up making another plate and another harness for my sons car. He does drives the car around 800 miles round trip to work.
Now the issues that he has is, that after driving the car for about 150-200 miles non stop the coils are swelling up and some had cracks as well and the coils stop working so I thought maybe the coils were touching the spark plugs and the heat is killing the coils. I decided to lift the coils a bit so the heat wouldn’t transfer to the coils but so far the coils keep doing the same thing.
I don’t understand why my sons car has this issue, my friend drives the car around 45 miles with traffic and never had an issue. This only happens when my son drives the car far, but in town the coils work perfectly fine.
I've seen some testing, the replica DENSO coils do crack and overheat. Toyota cancelled their coil production with Denso years ago, now the only OEM brand new coils you can get is through BOSCH, each coil costs 60$ or so, I'm ordering a set now as well. Almost made a mistake buying the fake Denso coils
One alternator could be a little stronger than the other, resulting in enough extra current to damage the coils. Driving conditions can matter to. 150-200 miles nonstop on the highway at higher RPM may put more heat into the coils, compared to stop and go at lower rpm. See post #4 for a more thorough description.
OE vs knockoff coils is also a good possibility, the aftermarket stuff usually does a better job of matching the outside, than they do at matching what matters: the internals.
All the coils I'm using are from Yaris or Prius OEM coils, they are used from the junk yard.
Coils are oem but used from junk yard, the problem is only in long drives, no problems on idle or cruising as long is not a long drive and definitely no problems at wot. The alternator stays around 13.8v on long drives.
This is what it is happening to the coils, and to me it looks like the problem is more like heat problems. The lower part is coming apart I guess from heat.
OK now that I see where that is, I would agree not related to dwell but heat from the head/plug. If you don't have good contact to the plug, it will arc there and definitely create more heat. Are the 2 cars running different plugs?
This is another version of wiring the prius/yaris/corolla coils to a "91-"94 1g dsm
Note:
the ptu connector is actually a maf wire connector that I extracted, and the wires go in from behind, but the front is shown in image.
