DSMnOOb00
- 903
- 4
- Apr 29, 2006
FRESNO,
California
I'm having crazy temperature problems with my radiator setup that consists of an all aluminum radiator and aluminum radiator shroud with 2 12' Slims fans (no brands)
Also I have Water wetter and dsmlink set to fans on high all the time
car idles and runs fine with the AC off but once you turn on the ac and start to drive, the temperature spikes. So I decided to go back on an all stock radiator setup including OEM fans.
My plan is to run two A/C fans to help clear the J-pipe, since the AC fan is slightly thinner then the main fan, I'm thinking it will be enough to clear the jpipe also the aluminum radiator is thicker then the OEM. I'm assuming it makes it harder for air to flow thru it causing more resistance. I'm also going to seal the bottom & sides of the intercooler and condenser to help channel the air thru the rad. I'm going to leave the top open to let air in during idle.
but I have a question, are both are equal? Is one of the fans better then the other?
thanks guys!
thanks guys!
